I can ground plug wire and get good spark but with plug there is no spark
SOURCE: change coil, sparkplugs, spark plug wires, icm and
Coil is bad
inspect for cracks
u could check for spark at the coil wire going into the distributer(center wire )
SOURCE: Chainsaw will not run, there is no spark detected
Homelite 330 – no points
http://www.acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/baf9791bfc773f1a88256c2600142688?OpenDocument
Please try this
Ignition Coil Test by SmallEng.com
http://www.youtube.com/watch?v=L7WNBDRG4C4
You may need to use a jumper wire between the threaded part of the plug and the cooling fins. You don’t have to bend up the electrode. HTH
Lou
SOURCE: no spark at plug
look for a light color coating on the parts if there is clean it off with sand papper check under the cap to
SOURCE: homelite ut10560 chainsaw good compression, good
check your fuel lines for cracks carb screen (if it has one) or jets might be clogged , also, I have a husk 350, fired only with gas in the carb, would not run at all just start and off. would not fire at all without doing that. the head bolts were little lose. I tightened them down put it back together, and that was the problem.
