Question about Food Mixers
Just bought kitchen aid prof 600 110v and i need a new transformer to 220v since my old one was busted using this appliance. What kind of transformer will i buy? Heavy duty ? Any spec? Thanks
Posted by Torch Bioyo on
Ross Keen
  • Food Mixers Master
  • 1,364 Answers
You need one that can deliver not only the correct voltage but sufficient current to operate fully when under load. Check the current requirement on the sticker under the base, it will give operating voltage and watts. Purchase a transformer that matches the voltage and exceeds the watts by at least 30% so that the transformer is not operating at full capacity when under load. It will not matter if the transformer exceeds the watts by 100% or more but they do get bigger and heavier as the wattage goes up.
Posted on Dec 25, 2015
  • Torch Bioyo
    Torch Bioyo Jan 03, 2016
    Thank you ross! I bought a 1000w step down transformer and it works.
    Cased closed:)
5 Related Answers
Anonymous
SOURCE: Kitchen aide mixer
i noticed my kitchen aide mixer is sounding like it is bogging down slightly while it is running it is not used very much and bought christmas 2007 others who own them have said theirs doesnt do that should i be concerned
Posted on Sep 05, 2008
Anonymous
SOURCE: kitchen aid 110v 450watt, I want to convert to 220v
Hi guys,
The only available Kitchen Aid stand mixers on the European markets are the Kitchen Aid Classic and the Kitchen Aid Artisan.
The best way is to contact a Kitchen Aid service center / repair facility in your area.
Here is the European website of Kitchen Aid: http://www.kitchenaid.eu/eu_EU/ka/ka_europe.htm
If you bought a different Kitchen Aid Stand Mixer (like the Professional series) you probably won't find the required parts to convert it to a European model. The only way would be to use a voltage converter.
I hope this helps.
Posted on Nov 04, 2008
woobie dog
woobie dog
  • 1273 Answers
SOURCE: kitchen aid--heavy duty mixer
The beater is held in place by a pin and spring arrangement. Lift and twist the beater. If that doesn't work, the pin is trying to come out...and is wedging against the beater. Tap the pin back in a bit, and the beater should release.
Regards, --W/D--
Posted on Jul 25, 2009
Anonymous
SOURCE: Kitchen aid stand mixer bought in US, moving to Europe, 220v 50hz
I can not respond to the warranty issues. My kitchen aid mixer is past warranty as well. I live in a country that uses 220V and my kitchen aid mixer is 110V. I have been using my kitchen aid mixer for almost 4 years with no problems at all.
The converter boxes are supposed to blow the fuse on the converter before it reaches your appliance and cause any problems.
If you purchase a 220V kitchen aid (although it would cost more money) it would probably have more power because of the higher voltage.
Hope this helps!
Posted on Jul 30, 2009
freetek
Steve Allison
  • 5569 Answers
SOURCE: I've the 325 watts its 110V kitchen aid and I
You will need a 'step-down' transformer with a rating of at least 500 watts (~500 VA), a primary designed for 220 Volts and a secondary rated at 110-115 Volts. This type will have four terminals or leads and isolates the input from the output.
There is a non-isolating type called an 'autotransformer' which has one winding with a tap (total of three terminals) roughly in the middle. I use this type for certain devices but it is not as safe as the first-described type.
If you are living in a foreign country that uses the ~220 Volt standard, you can sometimes get one on 'semipermanent' loan from the local utility.
Posted on Oct 07, 2009
My Kitchen Aid Aritsan was a gift bought in the US. We live in Zambia/Africa (using 240v electricity). One day there was a loud pop at the plug and a slight smokey smell. Its never worked since
I will assume that you were not using a step-down transformer (240 to 120 volts).
So what may have happened?
1. The phase board burned out.
2. The stator burned out.
3. The armature burned out.
4. The line cord and/or plug failed.
It could be one, all, or any combination of these things.
A solution is to simply convert the mixer to 240 volts. This can be done by replacing all four items above with the 240 volt versions.
If I were doing this here in the U.S., Ebay would be my source for the parts.
You can find a Service Manual which covers your model (even though it may net say so) and shows how it comes apart at:
http://www.kitchenaidparts.eu/documents/pdf/service-manual/classic-svc-manual-new-email-version.pdf
May 26, 2017 | KitchenAid KITCHEN AID 5 Quart Artisan...
Model 4ksm900b
Google Kitchen Aid in your home country.
Jul 30, 2014 | KitchenAid KITCHEN AID 5 Quart Artisan...
Oct 07, 2009 | KitchenAid K5SS Heavy Duty Commercial...
Mechanical burning smell on kitchen aid stand mixer
i think its time to retire it its has had a good run time to put it to rest and buy a new on it don't sound safe to use anymore
Sep 21, 2009 | KitchenAid KITCHEN AID 5 Quart Artisan...
Hope this helps!
Jul 29, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Kitchen aid 110v 450watt, I want to convert to 220v
Hi guys,
I hope this helps.
Sep 24, 2008 | Food Mixers
Food Mixers Logo
301 people viewed this question
Top Food Mixers Experts
Marvin
Marvin
john h
Lawrence Oravetz
Are you a Food Mixer Expert? Answer questions, earn points and help others
