Question about Lasko 48" Xtra Air Tower Fan with Air Ionizer
Remote control fan
Remote control does not do anything on my hunter ceiling fan. Light comes on on remote new battery but still does nothing.
Posted by noair on
Anonymous
Try holing the buttons for more than a second and the blades should start moving.
Posted on Apr 01, 2008
Anonymous
Most probable you have the same problem as I . Only mine does not turn on the light anylonger. I removed the controller from the fan assy and found the circuit board had fried for what ever reason. There is no replacement board available. So you will either have to wire in a new switch for the fan only, or replace it.
Posted on Dec 31, 2007
Remote missing on a Hunter Ergonomic fan. do not know how to take the base cover or light cover to see serial number. light cover has screws with no slots. base cover has no sign of srew holding it up. How...
Purchase the remote control, install batteries, and try it before taking anything apart. If the new remote control does not work, the internal receiver may have failed.
Dec 07, 2017 | Hunter 21871 56'' Ergonomic Brushed Nickel...
I NEED TO REPLACE THE CONTROL AND THE HUNTER TELPHONE NUMBER LEAVES ME ON HOLD FOR OVER AN HOUR WITH ANNOYING RECORDINGS!! HELP!!!!!!!!!!!!
i have a hunter ceiling not sure model but i have the model number 23530-300 with a remote ,the remote light comes on when you press any button but the fan does nothing any help good voltage
Jun 28, 2011 | Hunter Ceiling Fan Remote Transmitter...
My hunter ceiling fan stopped working then the light stopped put new battery in remote and still nothing works
it has a receiver for the remote control inside the electrical jbox up in the ceiling it may got damaged or check for power .
Jan 14, 2011 | Hunter Heating & Cooling
When I turn the light off with the remote control
im realy not trying to be a smart a*s but bont you only ever use lights at night?? i know i do?
it sounds like its the programer chip within the light that giving you the problem if taking the batterys out the controler dont stop this, its down to the light,
well there is one other thing it may be,,,
a friendly gost playing tricks on you???
or it could be that its getting a surge or spike of power from some were and that tricks the controler in the light to turn itself on???
sorry about that bit of fun as first just could not resist it????
Oct 26, 2009 | Hunter Ceiling Fan Light Remote Control
Hunter ceiling fan remote 85095-01 stopped working
it also could be one of the the jumpers fell out of the remote
they are located just above the battery. you will need to match the placement of the jumpers with the receiver mounted in the fan.
Aug 13, 2009 | Hunter Ceiling Fan Remote Transmitter...
Hunter ceiling fan w/ remote won't work
You need to change the receiver inside the fan. It is located in the top canopy of the fan. you don't have to buy a new remote just the receiver to save money and match the dip switches to the remote.
Nov 13, 2007 | Dryers
Hunter ceiling fan
Sounds like the remote receiver units (located where the mains connect to the fans) took a surge and have failed.
Jun 16, 2007 | Hunter Ceiling Fan Control Switch
Lasko 48" Xtra Air Tower Fan with Air Ionizer Logo
523 people viewed this question
Top Lasko Dryers Experts
Muntejaya Ginting
Muntejaya Ginting
Wbix
Ruth summersides
Are you a Lasko Dryer Expert? Answer questions, earn points and help others
