Question about Health & Beauty
The lights on the control panel started blinking three or four red lights and the chair has no functions,the chair is full charge
Posted by Duane Roberts on
5 Related Answers
Anonymous
SOURCE: The charge lights blink and the chair won,t go.
Just had this problem with my Guardian Aspire. They had to replace the electronic box with the joy stick. BIG BUCKS!
Posted on Mar 13, 2009
Anonymous
SOURCE: lights on hand control flash off and on and chair will not operat
There is a series of diagnostic flash codes associated with the controller. The diagnosis depends on which color and how many lights are flashing. If you post the combination, I can help you. Or you can download the Basic Operation Instructions of the Pilot Controller from the Pride website. The codes are listed on page two on the troubleshooting instructions.
Posted on Apr 14, 2009
Barry Nixon
  • 103 Answers
SOURCE: red light on my jet 7 keeps blinking and chair barely moves.
Sound like the batteries are on their last leg. Have them load tested.
Posted on Jul 23, 2009
Anonymous
  • 29 Answers
SOURCE: pride mobility Jet 3 Ultra Power Chair 7 flashing
a 7 Flashe code. There is a joystick fault. Make sure the joystick is in the center position and then power off and on again. Check all your couplings. make sure when turning on the unit you only mash the power button for 1 sec. 2-3 sec will put the unit in "Lock out mode".
This ierror will also be present if the joystick is off center when powered up. If you experience these symptoms, you must first make sure there is no physical damage to the joystick preventing it from returning to the center position. Then turn the power off and back on again (making sure the joystick is not depressed in any direction. If the joystick repeats this error, the controler much be replaced. [email protected]
Posted on Sep 07, 2009
HoverTech
Donna Angelo
  • 232 Answers
SOURCE: chair no longer charges, no flashing or blinking, lights,
The number of lights that are blinking indicate what the problem is. Visit this site to locate the type on controller on your power chair and you will be able to see that the blinking lights mean:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Try to reset your manual brake release as this is a common problem.
If you continue to have a problem, contact your manufacturer or dealer for service. If your insurance purchased they power chair for you, they may also cover the cost of repairs.
Posted on Oct 20, 2010
What dose red or yellow blinking lights on my jazzy pride electric power chair mean /
  1. VR2/VSI DIAGNOSTIC FLASH CODES
# OF LEDS
CODE
CAUSE
POSSIBLE SOLUTION
One red LED
Low battery voltage
Charge batteries
Two red LEDs
Left motor open
Make sure left motor is plugged into controller.
Three red LEDs
Left motor wiring fault
Contact your authorized Pride Provider.
Three red LEDs One yellow LED
Right motor open
Make sure right motor is plugged into controller.
Three red LEDs Two yellow LEDs
5
Right motor wiring fault
Three red LEDs Three yellow LEDs
6
Inhibit active
Three red LEDs Four yellow LEDs
7
Joystick error
Three red LEDs Four yellow LEDs One green LED
8
Controller error
Three red LEDs Four yellow LEDs Two green LEDs
9
Brake fault
Make sure both motors are plugged into controller.
Three red LEDs Four yellow LEDs Three green LEDs
10
High battery voltage
What if the speed LEDs on the VR2/VSI begin to flash?
  • Determine if the battery charger is connected to the power base. When the battery charger is connected to the power base, a charger inhibit feature keeps the power chair from driving. This is indicated by the VR2/VSI speed
    LED(s) flashing.
  • Determine if the charger harness fuse has blown. A blown charger fuse can cause the charger inhibit to
    activate.
  • Determine if all controller connections are plugged into the power base properly. If the 3-pin charger
    inhibit connector is not plugged in properly, then the charger inhibit feature will activate.
Oct 05, 2017 | Pride Health & Beauty
Why does my chair show a full charge yet after only a half a block it will show only red flashing lite indicating needing charge.
Your batteries are nearing replacement time. They are becoming incapable of holding a full charge.
Apr 28, 2015 | Pride Jazzy Select Elite
Pride Jazzy 1103 Ultra controller code: when the "on" button is pushed and held down, three red, four amber, and one green LED come on and are solid (not flashing), and there is a second LED gauge...
Seven blinking LED's indicate a "Joystick Fault" on the controllers Pride uses. Could be just the actual joystick itself, the part you move to make the chair move, or it could be other electronics in the controller. Here's a link to troubleshooting info:
Pride Mobility Products Corp Basic Troubleshooting Instructions
Dec 21, 2014 | Pride Health & Beauty
Jazzy 1133 has new batteries. All lights are lit on the battery condition meter. Maximum speed/profile indicator constantly blinks no matter how many sements are lit. After I turn it off and waiting a...
If all lights are flashing excessive voltage has been applied to the controller system. 6 flashing lights on the 1133 indicates that the chair is being inhibited by the battery charger. Try unplugging the battery charger. Check you battery connections.
Mar 30, 2013 | Pride Jazzy 1113 Power Chair
Hi I have a Jazzy 614 HD. I charge my chair with (new charger) and it turns off when fully charged and my Joy stick reads fully charged (New Joystick and new batteries) but within three to four hour
perhaps since your chair is over 2.5 years old you have underlaying problems such as motorheatup or excessive drag per a locked bearing or a bushingtrhat is out of lube.somebody needs to at everything that moves thathas to do withload carry,or powertrain.
Jan 12, 2013 | Pride Mobility Jazzy 614 HD Power...
When I plug it in to charge the red and amber lights stay lit and the green flashes and if i move the joystick everything is backwards push forward goes backwards left is right. b4 when it was plugged in...
sounds like a charger inhibit problem. Whenever you charge your chair the charger inhibit shuts down the chair so it can't be moved while charging. If you are getting this then that function is not working. Lets try this if you know of someone who has a chair or scooter with an off-board charger see if you can borrow it. Plug the off-board charger into the charger port located under the front of the joystick (don't have the on-board charger plugged in) and then turn the charger on. turn the chair's power on and you hopefully will see the lights blinking again indicating a charger plugged in (charger inhibit) the lights on the charger should be red and yellow (yellow turning green when fully charged) If you still get the problem with the off-board charger then your problem is in the controller or power module and this requires a new one. If Medicare paid for your chair you can call Repair Xpress @ 1-877-81-3733 or Roadrunner Mobility @ 1-800-467-2668 to have them fix it for you and bill Medicare for most of the repair costs. Hope this helps you
Oct 31, 2010 | Invacare Pronto M51 Power Wheelchair
Constant flashing lights,all three of the red, all of the yellow and one green. The chair was not at a full charge. I traveled approximately 20 feet, then I turned the chair around. Next ,I turned the...
You can visit this website to find answers on what the flashing trouble indicator lights mean: http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Locate the page that has the controller used on your power chair/scooter and count how many lights are flashing to diagnose the trouble. If your insurance purchased the power chair for you, they may also cover the repairs; contact them for information.
Oct 29, 2010 | Jet 3 Ultra Power Chair
Chair fully charged but quit running without for "no reason"
Are there any blinking lights? The number of lights that are blinking indicate what the problem is. Visit this site to locate the type on controller on your power chair and you will be able to see that the blinking lights mean:
Check all of your connections to ensure nothing has come loose. Ensure your batteries are not damaged and fully charged and that the fuses are good. If a power chair has been stored for a while the charger may indicate a full charge but the batteries are full of oxidized crud instead of power and need to be replaced.
Aug 05, 2010 | Electric Mobility Invacare Pronto M41...
Chair no longer charges, no flashing or blinking, lights,
May 07, 2010 | Pride Jazzy 1103 Ultra Standard Power...
Health & Beauty Logo
118 people viewed this question
Top Health & Beauty Experts
Marvin
Marvin
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Health and Beauty Expert? Answer questions, earn points and help others
