It has stopped reading the blank disk and occasionally the door will not open. I've removed the drive. Is there a source for a replacement drive, or a comparable one that will fit? It went into a ILO DVD recorder which I bought from Walmart about 5 years ago. It is no longer offered.
SOURCE: ilo dvd burner
Go online to update the firmware. If that does not work call the company to find out if they want you to ship it to them to correct the problem. There may be a recall on the unit. You do have a firmware problem in most cases. The other problem is that you may have to only use the same disk brand as the unit to get the system to work.
SOURCE: iLo DVDR04 Recorder
your dvd writer is bad you will have to replace it believe me i now what im talking about i have went through 4 ilo's did the same thing plus 100's of differnt name brand dvd's
SOURCE: LG recordable no longer recognized by pc
Go to Start/Control Panel/System/ Hardware /Device Manager/DVD/CD Rom Drives
double click on the Icon and click on the driver tab
click then on the update driver.
This will refresh the system.
But of course it may the the device itself that has failed
Only a replacement will cure that.
SOURCE: Panasonic DMR-EH75V DVD Recorder
I have the same unit and luckily there is a service center here in dallas tx called bayard electronics. I just dropped mine off there. check out the website at www.bayardelectronics.com
SOURCE: Lite On LVW-5045 DVD Recorder - won't record onto disc
Liteon lvw 5045 problem action failed.please consult our customer service for recovery. (error code: 0x810D0004)
