Question about Pioneer Car Audio & Video
How do you set the clock on a Pioneer DEH-6 A/FM/CD player with no aux input jack? thanx
Posted by James Yarbrough on
SAH67
    New Friend:
Real Answer to set Clock on Pioneer DEH-6 AM/FM/CD car player - DEH-6 will have no FUNCTION button.
1-Press SOURCE ("SRC" - button left of "1") and hold until unit powers off.
2-Press AUDIO ("A" - button upper right) and hold until clock appears in display.
3-Press </> arrows to select hour/minute to set - numbers will blink.
4-Press up/down arrows to increase/decrease hour/minute.
5-Press "BAND" or press "AUDIO" ("A") until unit powers off.
6-To check: Press CLOCK to turn on new clock setting display.
Posted on May 07, 2019
5 Related Answers
Anonymous
  • 8 Answers
SOURCE: HOW DO YOU SET THE
See instructions below:
Initial Settings
Adjusting initial settings
Using the initial settings, you can customize
various system settings to achieve optimal performance
from this unit.
1 Press SOURCE and hold until the unit
turns off.
2 Press FUNCTION and hold until function
name appears in the display.
3 Press FUNCTION repeatedly to switch
between the following settings:
CALENDAR (date and clock)—
WARNING TONE (warning tone)—AUX1 (auxiliary
input1)—AUX2 (auxiliary input2)—
DIMMER (dimmer)—S/W CONTROL (rear
output and subwoofer controller)—
DEMONSTRATION (feature demo)—
EVER-SCROLL (ever scroll)
Use the following instructions to operate each
particular setting.
# To cancel initial settings, press BAND.
# You can also cancel initial settings by holding
down FUNCTION until the unit turns off.
Setting the date and clock
Use these instructions to set the clock.
1 Press FUNCTION to select clock.
2 Press c or d to select the segment you
wish to set.
Day—Month—Year—Hour—Minute
As you select segments of the clock display
the segment selected will blink.
3 Press a or b to set the date and clock.
Pressing a will increase the value of the selected
segment. Pressing b will decrease the
value of the selected segment.
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/415128381DEHP4900IBOperationManual0216.pdf
Posted on Aug 20, 2010
Anonymous
  • 86 Answers
SOURCE: clock setting
Setting the Time
This is the mode for setting the time on the unit’s clock display. (Refer to page 51 for
details concerning the clock display.)
As soon as you switch to “Minute”, the seconds start counting from 00.
1. Press the FUNCTION button and select the Time setting mode in the InitialSetting Menu
always select “OFF”.
2. Select “Hour” or “Minute”
with the < / > buttons.
3. Set as desired with the ^ / v
buttons.
Posted on Jan 04, 2009
mikehumble
  • 124 Answers
SOURCE: how do i turn aux on my pioneer deh-7600mp radio
Shut it off then hold the function button, cycle through till you find your option to turn it on, the turn the radio back on and use you source button to change to CD, TUNER, and AUX
Posted on Dec 27, 2008
mikehumble
  • 124 Answers
SOURCE: SETTING CLOCK FOR PIONEER Deh p49001b' CD AM/FM/
shut it off then hold the function button
danjoethurau
Daniel Thurau
  • 20 Answers
SOURCE: setting radio station to a channel on a Pioneer DEH-525R cd player
Scroll to the station then press and hold the preset button you want it to goto.
Posted on Aug 07, 2008
Pioneer DEH - P2900MP How do you set for Aux 2 . I can get Aux 1 , CD and am/fm
What's not explained in the manual is that you need to do this while in the clock setting mode. Radio OFF/ press and hold SOURCE/ while in this mode, press FUNCTION to scroll thru the auxiliary inputs/ press ^ & v to turn on and off/ SOURCE to exit.
Aug 18, 2012 | Pioneer DEH-P2900MP CD Receiver...
DEH = 2700 AUX TURN ON
The deh-2700 doesn't have an aux input. The headphone jack in the back is for a wired remote.
Jan 07, 2012 | Pioneer DEH-2700 CD Player
How do u set clock on deh p3000 pioneer
This was copied from the Pioneer support site:
Clock adjustment is performed in the "Initial Settings" menu. Please follow the instructions below to access time setting.
Press & Hold [OFF]
Pres & Hold [Muti-Control] until "Clock Set" Appears
Turn [Muti-Control] to choose setting
Press [Muti-Control] to enter setting
Time Setting:
Press [Muti-Control] to select time setting mode
Press [Muti-Control] to select time segment. Each press will select one segment of clock
Turn [Muti-Control], or click up/down to adjust time segments
Available functions:
Clock Set, Warn Tone, AUX 1, AUX 2, SW Control, Ever Scroll, BT Audio*, Pin Code Input*, BT Ver Info*
*Available only when bluetooth adaptor is connected
Feb 24, 2010 | Pioneer DEH-P3000 CD Player
Ipod worked with my pioneer deh-p3700mp before
this works on some other pioneer head units i encountered it may work on yours.
Shut it off and hold the function button until the options appear then you can scroll through and change a bunch of settings including the aux input
Dec 31, 2008 | Pioneer DEH-P3700MP CD Player
Ipod?
Get an ipod fm transmitter if you havent got any aux input
Apr 19, 2008 | Pioneer DEH-P7300 CD Player
Having trouble settimg clock on cd car stereo
how to set clock for a pioneer deh-27mp
Mar 24, 2008 | Car Audio & Video
Connect ipod to cd player wit built in aux input.
VERY SIMPLE SOLUTION FOR DEH-P5800MP!!!!!!
Turn unit off by holding the Source (volume knob) button until power is off.
Now, hold down the Function button (FUNC) until the unit turns on. You will now be in the Initial Settings menu, a special menu. Press the Function button (FUNC) again until you see the word AUX, press up to enable it, then press the Source (volume knob) button until you see AUX. It works now, congratulations.
Sep 22, 2007 | Car Audio & Video
Auxilary
If your cd player is a DEH-P4600MP (mp3 player)then you have to turn off the player first, then press the button on the upper right hand corner of the faceplate and then scroll through the menu and find aux to turn it off or on with the "wheel" on the right on the faceplate. You will also find the alarm and clock settings there in the menu as well but the key is to make sure the player is off first while doing this or you can't access the menu. To use the auxillary input on the back of the unit you need to purchase (eBay has them) an aux input adapter ref CD-RB10 cable. Hope this helps.
Aug 01, 2007 | Pioneer DEH-P4600 CD Player
Car Audio & Video Logo
139 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
