Question about Radio Communications
How can I repair bluetooth pairing
I cant seem to get the dock to pair with my phone. The Bluetooth light just keeps flashing and flashing and flashing
Posted by Allan Levson on
Reisha Hermana
    New Friend:
    Problem Solver:
  • 13 Answers
Depend on your phone brand. Some brand like sony iPhone, in some case can't pair (Bluetooth) with another device
Posted on Dec 26, 2015
5 Related Answers
Anonymous
  • 108 Answers
SOURCE: Bluetooth pairing
1.Explore blue tooth devices from your motorola phone.
2.it will sure find your blue tooth headset.
3. Make sure your blue tooth headset is on
4.in pairing function select your blue tooth headset
Posted on Dec 22, 2007
Anonymous
SOURCE: pairing samsung wep200 bluetooth with motorola V3xx Razor
hold that reciever button until the light is a still...you may have to hold it for about 10seconds and once the still blue buton has come then search for devices on your phone.
Posted on Dec 27, 2007
Anonymous
  • 5 Answers
SOURCE: Need to re-pair bluetooth to phone
Go to ur phones bluetooth settings - activate pair new device - at the same time press and hold the on button on your blue tooth head set for about 10-15 seconds - this will enter the device into pair mode - on your phone - click on pair with new device etc etc, the default access code is either 0000 or 1234
Posted on Jun 29, 2009
Anonymous
  • 5 Answers
SOURCE: Motorola bluetooth H270 solid blue light after pairing
I had the same problem. I plugged a USB charger into the headset and turned the power switch off. It worked as normal after that. I think it does not like to be "on" when the USB is disconnected. Anyway it seems the plugging/unplugging kick-started it.
Posted on Feb 12, 2010
award462
Anthony Ward
  • 397 Answers
SOURCE: pair bluetooth em227 with my phone
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above. Then you can discover it with your phone. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
Posted on May 06, 2010
How do I pair a Victsing Bluetooth speaker to my cell phone?
Hi
Try this.
Hold Down Power: Many Bluetooth speakers switch into pairing mode by turning the speaker off, then turning the device on while keeping your finger depressed on the power button. To notify you the speaker is in pairing mode, it will typically emit a sound or its light indicator will begin flashing rapidly.
Hold Down Pairing Button: Some Bluetooth speakers have a dedicated button for placing your device into pairing mode. Seek out a button on your device with the Bluetooth symbol next to it, then hold it until you hear your speaker emit a sound or its light indicator begins flashing rapidly.
your Bluetooth speaker now discoverable, it can be paired to your iPhone or Android phone.
Quick Pairing Instructions
  1. Open Settings.
  2. Open Wireless and Network.
  3. Open Bluetooth® Settings.
  4. Turn Bluetooth® on if it is off.
  5. Touch Search for Devices.
  6. Touch and hold - UGO.
  7. Touch Connect.
Mar 24, 2017 • Cell Phones
3answers
How do I pair speaker with phone
turn both phone bluetooth and speaker bluetooth off. then turn them back on. the speaker's light should be flashing indicating its searching for a device to pair with. as its flashing make sure your phones bluetooth is visible and searching. they will pair and your phone will tell you and the speakers light should quit flashiing and just remain on.
37helpful
2answers
I cant pair my jabra bluetooth to my evo!
First, put the headset into pairing mode. To do this, remove it from the Stone charger and press and hold the answer/end button until the lights flash four times slowly - this indicates that the unit is off. Then, press and hold the answer/end button again - you'll soon start to see lights flash - hold the button until the green light is on steady and the blue light is flashing. This is pairing mode. Now your Evo should be able to "find" the Stone to pair with it from within the Bluetooth menu on the phone.
I am trying to sync a new bluetooth (sprint brand) to my blackberry curve 8330 I have bluetooth enable and have searched to locate the bluetooth earpiece and it keeps saying can't be found
You have to make sure the bluetooth is in a pairing mode for the blackberry to discover it on most bluetooth they have a pairing button turn off your bluetooth headset hold pairing button till the light is solid or flashing red and blue depending on model then search for new should find it
Sep 24, 2009 • Cell Phones
26helpful
2answers
Bh 101 bluetooth headset lost manual and forgot pairing code
Try this: 1. Ensure that your phone is switched on. 2. If the headset has not been previously paired with a device, switch on the headset. The headset enters the pairing mode, and the indicator light starts to flash blue quickly. If the headset has been previously paired with another device, switch off the headset, and press and hold the multifunction key until the indicator light starts to flash blue quickly. 3. Activate the Bluetooth feature on the phone, and set it to search for Bluetooth devices. See the user guide of your phone for instructions. 4. Select the headset from the list of found devices. 5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones, you may need to make the connection separately after pairing. You only need to pair the headset with your phone once. If pairing is successful, the headset appears in the menu of the mobile phone where you can view the currently paired Bluetooth devices. When the headset is connected with your mobile phone and ready for use, the indicator light of the headset slowly flashes blue.
Apr 14, 2009 • Cell Phones
1helpful
I cant pair my bluetooth to my blackberry pearl flip phone but my
If you have lost the pairing on your phone with the headset follow these simple steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Explorer 3XX device and click add
6) You will be required to enter in a pass code which is standard ‘0000’
7) If successful then the headset will start flashing BLUE every few seconds.
8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device.
• The headset is now paired with the phone
Bluetooth 350
It might be the pairing has drifted slightly. I would try repairing again. It certainly cant hurt anything.
1helpful
2answers
Cant connect logitech bluetooth to phone,
the logitech head piece buttons must not be working, seems to charge ok but can't get to flash blue?
Bluetooth keeps flashing
1. SWITCH ON THE POWERBUTTON BTHS AND PRESS THE PUSHBUTTON FOR A FEW SECONDS UNTIL THE
LIGHT STOPS BLINKING.
NOW YOU CAN SEARCH FOR THE BTHS. AFTER SEARCHING PAIR IT ,PASSSWORD IS 0000.
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Ekse
Are you a Radio Communication Expert? Answer questions, earn points and help others
