Samsung Yp-U6qb U6 2Gb Mp3 With Fm Radio And Usb Slide - Black Logo
D
Dinesh Posted on Dec 18, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I connect it to laptop its getting charging but it doesn't display to open???How to solve this problem????
Will Mishler
Level 2:
Sergeant:
  • Expert 307 Answers
  • Posted on Jan 25, 2016
Will Mishler
Expert
Level 2:
Sergeant:
Answers
307
Questions
0
Helped
75062
Points
741
Make sure it is powerd on when connected to the pc most devices need to be on for the computer to find them
Not charging & No Display
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
THEY ARE PLUGGED INTO MY LAPTOP AND THEY WONT CHARGE.
First Option:
Second Option:
I can't open my xtuch x704 when i charged it it
First Option:
Second Option:
Nov 03, 2012 • Cell Phones
2helpful
2answers
I have an HP G62 225dx that shows a cracked screen on the display. When I hook up an external monitor it does not display correctly. Does the motherboard need replaced?
If the screen still doesn't display properly when connected to an external monitor, then there is probably a problem with the graphics chip on the motherboard. This can usually be repaired, but you'll still need to use the external monitor unless you get the screen replaced as well!
My laptop screen turned white all by itself while running. I turned it off. Now, when I start the laptop it displays the same white screen after the boot. The white screen is stripped with blue, black and...
Hi there, most likely there is a problem with either the GPU of your laptop.
The only other troubleshooting step you can try is to open the laptop up and reseat the connector of the LCD to the motherboard where your GPU is integrated.
You may also want to try an external monitor and if nothing is displayed or the same screen is displayed then the GPU of your laptop is fried and it needs to be replaced.
Hope this helps!
My laptop is dell inspiron 1525 but battery is not charging i have replaced the battery and even i have used new adapter but i cant solve the problem please help me to fix it
Hi
please remove the battery, plug-in the charger and turn ON the laptop, if it doesn't work,
then the internal part that connects the laptop to the charger have problem and need to be fixed through a technician.
Good Luck
7helpful
3answers
My Sony Walkman NWZ-E344 not show anything to display. Display show only logo & i have connect pc then show "connected USB.the timer and Alarm will become invalid" pls solve this...
pls solve this problem?
Gateway laptop wont connect to power
The only thing you can really do in this case is call gateway and see if they can repair this. it seems like something internal. Hopefully the computers are still under warranty. Sorry for the bad news.
Laptop is not able to open windows. mine is HP pavilion dv4000 p/n is EP360 UA#ABA- dv4320us
If the laptop boots up press F10 when F10 is displayed on the lower left of display and ensure that the hard drive is selected for first boot. If Windows still doesn,t boot then put the system restore cd/Windows cd in and boot from that.  If the display has nothing make sure that the brightness is not turned down or connect an external monitor. At this point repost to get more info.
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
