Question about SanDisk Sansa e250 MP3 Player
Evry time i turn on it comes up with sandisk then...slowly fades out white and does this again...untill i reset
My sansa e250 comes up with sandisk every time i turn on...and slowly fades out white and does this again...untill i turn it off(holing shut down button 15-20 sec)... to solv this problem i tried every thing, like - recovery utility, new firmware installation, upload pp5022.mi4 - as i suggest by fixya solutions... but still i'm not get work it properly... pls help... wht to do ??? i'm deing without my ipod ... thank u
  • 2 more comments
  • Anonymous Nov 17, 2007
    Mine does the same thing. Every time I turn it slowly fades it to white..and than it does it again. I don't know how this happened. I was listening to it right before this happened. I Need help.
  • Anonymous Nov 20, 2007
    now i have another big problem after trying as more solution as posible .... now only blue ring is appeared ...its not getting start any more... i tryied to reset and start again , but no more option... not even sandisk appear... pls pls pls help...
  • Anonymous Dec 16, 2007
    it fades out and turns off and on. its does everything once its on but it wont play my music. it forgets i turned it on and it comes up saying english,spanish etc... it turns off and on then fades away . what do i do?
  • Bengjie Dec 19, 2007
    i have the EXACT same prob..and i cant even get it to boot up...and i tried to do the recovery but the buttons it tells me to hold are different ...from an older model i think.
Timothy D
  • 626 Answers
Try this;
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://rapidshare.com/files/67740173/e200fw01.00.12.exe____
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Posted on Nov 17, 2007
  • Timothy D
    Timothy D Nov 20, 2007
    If you use the tool I sent you, it will resolve the Blue Ring Problem also.
    Just follow the directions.
    Best of Luck.
Anonymous
My sansa turns on but dissapears and comes back again
does this device gets detected by the computer? if yes then do a formware upgrade. this is due to firmware problem.
Jul 27, 2009 | SanDisk Sansa e250 MP3 Player
Sansa e280 8 gb
I took my Sansa back to the store under warrenty, They exchanged it straight across. Really the only advise your team gave me was to take the battery out and turn the unit back on- I had already done this several times before I contacted your site. I wasn't thrilled with the advise given to me
Aug 02, 2008 | SanDisk Sansa e250 MP3 Player
Sansa 8.0 gb
refer to the anythingbutipod.com forums for help correcting this problem. they have a specific sansa e200 forum.
It says "bad track" and shuts off while connecting to my computer.
switch the cord into a different usb slot while it was loading
May 17, 2008 | SanDisk Sansa e250 MP3 Player
My sansa wont boot up
The best results that I have had were to hold the power button for about 15 seconds. ( if you only hold it for 3 seconds it goes into sleep mode). This shuts the device off. Then restart it.
Dec 12, 2007 | SanDisk Sansa e250 MP3 Player
Slowy fades to white
This will take care of it.
Best of Luck.
Nov 17, 2007 | SanDisk Sansa e250 MP3 Player
Flashing screen
Try this;
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
Best of Luck.
Oct 29, 2007 | SanDisk Sansa e250 MP3 Player
Blank White Screen - No Menu Showing
My Sansa has a similar problem. Sometimes when the Sansa turns on (after the Sandisk logo) the screen will either turn black, blue, or black and white stripes. The player still works, but it is hard to navigate without the screen, obviously. What I end up doing is letting the backlight turn off and then pressing any button. Sometimes when the screen comes back, the display is allright again. But sometimes it takes more than a few tries. Turning it off and on again seems to work a little better, but it is more time consuming.
Apr 01, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
61 people viewed this question
Top SanDisk Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
