Question about ASUS Eee PC 1005HA-PU1X-BK Netbook
What am I doing wrong? No Signal.
I have an Asus but the screen is cracked so Im connecting it to an AOC monitor. When they first come on the monitor shows its loading Windows XP but then it goes straight to NO SIGNAL... WTH?? Ive connected the Asus to tv before a long time ago but cant remember. Can someone please help me? It cant be that dang hard. 1 cable from monitor to Asus and 1 cord each to plug into electric-not complicated.. LOL.
Posted by Malinda Blanton on
How do I attach this monitor to my laptop to use it as a second screen Please?
How do I connect my laptop to an external monitor - Page 2 ...
h30434.www3.hp.com > Laptop & Notebook > Video/Touch
May 6, 2013 - 10 posts
I have a pavillion dv5 2070us and the screen is cracked and I can't see ... I have a pavilion dv6, can someone please tell me the order of the menu ... 06-01-2013 08:19AM ... Once I connected my laptop to the extra monitor, the screen on my extra ...Connect your second monitor while the computer is on. 2.
The HTG Guide to Adding an Extra Monitor to Your Laptop
www.howtogeek.com/.../the-htg-guide-to-adding-an-extra-monitor-to-y...
Aug 7, 2014 - Adding extra screen space to your laptop, however, can be quite a bit trickier. ... If you're looking to do the same, to add a little space to your laptop ...Playing Minecraft on the second monitor was a smooth experience with no drop in FPS. ... Because the AOC does what it does so well, we'll use it to highlight ...
AOC E1649FWU 16-Inch 1366 x 768 16 ms LED LCD Monitor
www.amazon.com/AOC...Monitor/dp/B005SEZR0G
Amazon.com, Inc.
Rating: 3.8 - ‎1,067 reviews
Jan 04, 2016 | AOC 936sw 19" Widescreen Lcd Monitor -...
AOC 2036S won't connect to laptop
Is the cable working? try reducing your laptop screen resolution and connect to your monitor. Your monitor may not support full hd resolutions....
Jan 09, 2014 | AOC 2036S 20 INCH BLK LCD MONITOR
Aoc monitor turns on but says no signal and wont work
the problem is not on the monitor your system unit is the problem...maybe the RAM memory,video card or very high resolution try to load in other monitor and down the resolution to 800 X 600..
Dec 07, 2013 | AOC Computers & Internet
New AOC monitor. No sound . when i insert dvd which was in the package it just promotes AOC products
Did you plug the sound sable into the audio out port on your computer?
The VGA and DVI monitor cable/plugs do not have sound capability so if there are speakers on your monitor they need to get the sound signal through a separate wire.
HDMI can send sound so if your monitor is hooked up via HDMI it should be able to pass sound as well (at least in most circumstances).
Mar 12, 2011 | AOC Monitor
I bought an AOC 2036s monitor in the usa, came back to australia to connect it to my laptop as a second screen. yet it wont seem to work, i keep getting no signal. the box saids compatible with XP, yet...
USA mains equipment operate on 110 volts. Unless the AOC monitor can operate on multi voltages ie 110 to 240 volts, when you connect 110 voltage equipment into 240 volts mains in Australia you most likely will damage the AOC monitor.
To operate equipment that has been designed for 110 volts, you need to purchase a step down transformer from 240 to 110 volts that has suitable wattage rating for the AOC monitor.
Feb 24, 2011 | Computers & Internet
AOC 1" - Monitor Says "no signal"
Sounds like a connection problem. Make sure BOTH plugs are securely located. Ian.
Sep 20, 2009 | AOC LM729 17" LCD Monitor
Color coding in signal cable for AOC CRT monitor
what do you meen by (color coding in signal cable for AOC CRT monitor) i might be able to help you if you can explane what you meen thank you.
Apr 22, 2009 | AOC CT720G 17" CRT Monitor
Monitor display image
press control+alt+down(arrow key)
May 14, 2008 | AOC A15X221 15 in. LCD Television
ASUS Eee PC 1005HA-PU1X-BK Netbook Logo
Top ASUS Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Roy May
Marvin
Marvin
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
