I purchased a power board but it seems Parental Control is locked,
You will need the TV remote control to reset, but here is the manufacturers User Guide download link with all the info you need:
RCA Television
SOURCE: Parental Control Lock
I'm really guessing here - -but while you're in the parental controls screen I believe you can use 0-0-0-0 as a backdoor key. It's different for every manufacturer, Philips uses 0-7-1-1 example. But the users's manual for that TV says that the "default" is 0-0-0-0.. Don't really understand their use of that terminology so it's merely a guess... But here's something I am really sure of;;; The owner's manual can be downloaded for free at the Vizio web site: http://www.vizio.com/support/downloads/ and their support line is: 1-888-849-4623 or you can email tech support at: [email protected] Hope this helps. Good Luck Bill
SOURCE: How do you cancel parental control?
If you forget your password, simultaneously press and hold the MENU/
OK button on the front panel and VOLUME down button on the
remote for three seconds. This resets the password only and unlocks the
TV; all other settings in Parental Controls are not changed.
Page 48 of the manual.
SOURCE: Reset Parental Control
Press and hold both VOL- on the TV and 0 on the
remote control simulaneously for a few seconds
until the LOCK menu appears on the screen and
then the password should be cleared.
SOURCE: parental control lock
Here is the user manual, check page # 40 on how to clear the secret code.
hi,
To unlock your TV you must need the original remote of it. If you don't have then you have to purchase it. After the do the following for unlock you TV
Apex TVs have parental locks that allow you to block certain programs based on their rating. When this feature is no longer needed and you want your TV to display all programming no matter its rating, you must unlock your TV. Unlocking your Apex TV is done completely from your remote control and does not require any tools. The process takes less than 5 minutes.
1. Press the "Menu" button on the remote control and use the arrow buttons to scroll down to the "Parental Guide" option, then press the "Enter" button.
2. Type in the default parental code "6688" if you have not set your own code. If you have set your own code, type it in. If you set your own code and forgot it, override it by using "6688."
3. Use the arrow keys to switch the parental lock to "OFF." This allows all programs to be viewed no matter the rating. Press the "Exit" button on the remote and start watching all your channels
ok
