Question about Apple iPod touch
Ipod is disabled, how do i restart it ? - Apple iPod touch
Posted by lyana cruz on
Brian Sullivan
  • Apple Master
  • 27,725 Answers
The iPod Touch is a type of iPod that features a touch screen and can function as both a portable media player and as a pocket computer.
It is possible to password protect your iPod Touch so that you will have to enter a password every time you want to unlock the iPod Touch screen.
If you repeatedly enter the incorrect passcode, your iPod Touch will become disabled.
To unlock a disabled iPod Touch, you need to sync your iPod Touch device with iTunes on your computer.
Attach the iPod Touch data cable to the bottom of your iPod Touch device and attach the other end of the data cable to an available USB port on your computer.
Open iTunes on your computer and then select your iPod Touch device from the list of available devices on the left side of the iTouch window.
Click the "Restore" button.
If you have previously backed up your iPod Touch, you can choose to restore the device to the last back up or any saved backup.
If you have never backed up your iPod Touch, this process will restore your iPod Touch's factory settings.
Wait while iTunes syncs with your iPod Touch and restores the device.
iTunes will prompt you when this process is complete.
or
A hard reset restores your iPod Touch to its original factory settings.
This is useful when your iPod Touch is disabled and won't turn on or off, but all your data is erased.
Luckily, you can restore your data with iTunes after you've performed the reset.
Once you've performed the reset, your iPod is wiped clean and iTunes prompts you to restore the settings from your last sync.
Plug the iPod into your computer and wait at least 10 minutes.
This allows the battery to recharge in case it has drained.
This could fix your disabled iPod, if the problem was caused by a dead battery.
Click "OK" if your computer opens a "Connect to iTunes" alert box.
Depending on your version of iTunes, the message may indicate the iPod is in "recovery mode" and you need to restore the device.
ITunes opens and resets your iPod for you.
Unplug the iPod from your computer if you don't see the "Connect to iTunes" alert box.
Make sure the iPod is charged before you attempt the hard reset.
Press and hold both the On/Off/Wake button and the Home button on your iPod.
Keep the buttons pressed.
Wait for the Apple logo to appear, it may take 10 seconds or longer.
When you see it, release the On/Off/Wake button but keep the Home button pressed.
Release the Home button when you see a picture of a USB cable with an arrow pointing to the iTunes logo.
Plug your iPod back into the computer.
The iTunes "recovery mode" message will appear.
Click "OK" to complete the reset.
Posted on Dec 30, 2015
Ipod is disabled...it says ( connect to Itunes)but it won't do anything.
Really need more info but try this link or leave more info in the comment section.
iPod nano Support
Apr 29, 2014 | Apple iPod nano
Disabled passcode restore
go to system menu and find the restart button or click the off button and the other on
Dec 27, 2013 | Apple Ipod Touch 4g
How to restart a disabled ipod
If you enter the wrong passcode repeatedly on an iPod Touch, it will display a message that says "iPod is disabled." At first, the iPod will only be disabled for a minute, but if you continue to enter the wrong passcode, it will become disabled for longer periods of time, and finally, you will need to connect it to the computer with which you last synced it. From here, you will need to restore the iPod Touch to factory settings.
Open iTunes. Click "iTunes" in the upper-left corner, then select "Check for Updates" to ensure you have the latest version. Connect your iPod Touch to your computer with the USB 2.0 docking cable. Click your iPod's name under "Devices" on the left-hand side of the iTunes browser. Click the "Summary" tab. Click "Restore." Follow the prompts in the dialog box that appears to finish the restore. Your iPod will return to factory settings. Choose to set up the iPod as a new iPod or from a backup in the screen that appears when the restore is complete.
Apr 13, 2013 | Apple iPod touch
Itouch displays "disable connect to iTunes" how can I restore it?
Restart iPod touch
To restart iPod touch, first turn iPod touch off by pressing and holding the Sleep/Wake button until a red slider appears. Slide your finger across the slider and iPod touch will turn off after a few moments.
Next, turn iPod touch on by pressing and holding the Sleep/Wake button until the Apple logo appears.
Is iPod touch not responding? To reset iPod touch, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds, until the Apple logo appears.
If your device does not turn on or displays a red battery icon, try recharging next.
Dec 02, 2012 | Audio Players & Recorders
We are getting a message that the ipod touch is disabled, and it is telling us to connect to itunes. When we connect, it tells us to enter the passcode into the ipod, which is impossible when the ipod is...
I have a very easy solution for this. But let me warn ou that this will cause a permanent loose of all kind of data stored on your ipod.
Connect your ipod touch to your pc.
Hold both home and power button until it restarts and shows connect to itunes sign.
Now your itune will ask you to restore it.
After the proccess is done you will have your ipod unlocked and back to its factory settings
Dec 29, 2009 | Apple iPod touch
IPOD TOUCH HELP
You have to restart it by putting into DFU mode then restart it through Itunes
Jun 08, 2009 | Microsoft Xbox 360 Console
Ipod disabled
mine is doing the same thing "ipod is disabled try again in 60 minutes" idk what wrong but my ipod is only 2 weeks old.
Jul 06, 2008 | Apple iPod touch
Ipod touch disabled
If you repeatedly enter the wrong passcode, iPod touch will be disabled for longer intervals, before you can try again.
After too many unsuccessful attempts, you won't be able to try again until you connect to the computer you normally sync with.
So you have to give the touch back and have it connect with the original pc. Or then loose all the files with a update/restore.
May 17, 2008 | Apple iPod touch
Apple iPod touch Logo
444 people viewed this question
Top Apple Audio Players & Recorders Experts
Ekse
ThaMp3Doctor
ThaMp3Doctor
Sean Cole
Sean Cole
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
