i am having canon pixma ip 2700 inkjet printer. it worked properly till. I got refilled both cartridge and fix it in my printer but the cartridge was not recognized. i had tried installing the cartridge many times and also tried switch off and on it again many times but the printer shows the same error that "An error occurred.Some ink cartridges cannot be recognized." and a message box is opened and it shows that "An ink cartridge is not installed properly.Open the printer's cover, make sure the ink cartridge is installed properly, and close the cover." help me to recover from this problem i can't afford to buy new cartridges. suggest me some ideas and procedures to
The ink cartridge carrier moves and stops at the loading
position unless the printer is busy.
Turn on your printer.
Lift the printer unit, and position the scanner support
between the tabs to hold it open.
The ink cartridge
carrier moves and stops at the loading position unless the printer is busy.
Press down on the ink cartridge lever to raise the ink cartridge
lid.
Remove the old ink
cartridge.
Dispose of the old cartridge properly.
If you are installing a new ink cartridge, remove the
sticker and transparent tape from the back and bottom of the ink cartridge.
Insert the new ink cartridge.
Snap the lid closed.
Lift the printer unit, and hold the scanner support up while
lowering the printer unit until it is completely closed.
DON'T FORGET TO RATE THE SOLUTION, THUMBS UP!
removed and replaced many times with no luck. The status monitor for the printer on the computer shows both ink cartridges to be 100% but the printer still says the cartridges are not installed. I have turned both machines on and off several times. Any advice
