Question about Sharp 21B-S10 21" TV
Standby mood - Sharp 21B-S10 21" TV
How do i stop my machine from staying in the dryer cycle and turn it back into wash mood
What controls when you are in the mood to wash, or in the mood to dry? Perhaps the weather, or it's related sounds?
May 12, 2017 | Washing Machines
Tip
Perfume as a mood enhancer
Perfume is also a powerful mood enhancer. So, if you are not experiencing the best of moods, you may want to consider a fragrance that will pick you up and put you in a better mood.
on Nov 23, 2010 | Health & Beauty
What is a euthymic mood
Euthymia is a normal non-depressed, reasonably positive mood. It is distinguished from hyperthymia, which refers to an extremely happy mood, and dysthymia, which refers to a depressed mood. It is a term used frequently in mental status exams.
The term is also sometimes used referring to the neutral mood (absence of a depressive or manic cycle) that some people with bipolar disorder experience with varying frequency.
May 21, 2014 | Computers & Internet
How can i formate my c101 and i did not know my code
To format your Nokia C101 Phone first make sure that your phone is off. Then press * + 3 + Call Button + Power On Button at the same time. Before the device is reset you need to provide the default lock code 12345.
If not working try these another steps. You can format your device by typing the *#7370# in standby mood. Before the device is reset you need to provide the default lock code 12345.
Apr 04, 2013 | Cell Phones
My nokia 5233 mobile phone standby mood and camra not activet
first format ur cell phone.otherwise it not work ur cell phone camera is damged.
Feb 10, 2011 | Nokia BNIB 7900 PRISM SIM Free/Unlocked...
A friend told me that a prefume can sometimes influence moods..it is true?
Yes, various studies show that fragrances can influence moods. Some studies show the impact scents have on moods may come partly from memories they invoke. Therefore, a mood change may vary from person to person or at different times. A pleasant fragrance can both soothe and stimulate.
My tv is staying in standby mood
count # of flashes , if any, call tech support.
Maybe power board
Jun 02, 2010 | Sony KP-51HW40 51" Rear Projection...
On then went off but power light is standby moode
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 19, 2010 | Relisys TL 766 Monitor
Have a Samsung LE19R86BD which is stuck in DTV mode showing channel 303 303 ( showing 303 twice) Prior to this I could only scroll down to channel 32 then it woudn't let me scroll down any further. This...
Solved the `stuck in DTV mode' by pressing 01 numbers on the remote. This freed the problem.
Still cannot get scroll to pass channel 32 though!
Nov 22, 2009 | Televison & Video
Screen get white when unused for sometime
Just disable the Hard Disk Mode, Hibenation Mode and StandBy Mode at your display properties to avoid hang-ups and system crashes.
Sep 24, 2009 | Acer Aspire 4315 Notebook
Sharp 21B-S10 21" TV Logo
48 people viewed this question
Top Sharp Televison & Video Experts
Ekse
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
