Question about Altec Lansing Audio Players & Recorders
How do I fix the charging port on my altec Lansing jacket h2o speaker
Posted by donald hansing on
5 Related Answers
Anonymous
  • 277 Answers
SOURCE: Sub Woofer does not work
hi there are fast checkings for you: Quick Connect Card http://www.alteclansing.com/downloads/641QCC.pdf manual: http://www.alteclansing.com/downloads/641_MAN.pdf is the system working fine exept the sub? my guess: the headphone jack works fine then the speakears are too if soo then the sub amp is bad or some connection is torn try opening the sub and see if everything is hooked right and if soo then the amp is the problem every electronics shop can fix this good luck
Posted on Mar 21, 2006
Anonymous
  • 4 Answers
SOURCE: how to repair atp3 altec lansing
Best bet would be to just strip the wire with a wire stripper or utility knife and twist the bare ends together to fix the connection. A little electrical tape around those wires and you should be almost good as new. Of course you might notice some difference in quality but I'm pretty sure the only way round that would be replacing the cable.
Try it out and let me know how it works out for you. If you know how to solder it might be a good idea to solder the connection as well.
Posted on Jan 05, 2008
Anonymous
SOURCE: Altec Lansing ada745 fuse
Yes, it's a 1A 250V glass fuse, 0.75" (1.9cm) long. The only other number on the fuse is "239", if that means anything. You take it out by putting a flat screwdriver in the slot on the fuse holder cap, turn counter-clockwise, and pull out once it releases.
Posted on Nov 20, 2008
Anonymous
I work for a charity that had one of these donated today and as I was looking for a new sub for my cinema system I purchased it. I have no other speakers with it and no way of switching or varying the volume. I opened up the back of the sub and slid the board partly out exposing the PCB.
[IMG]http://i134.photobucket.com/albums/q116/mm0dxc/PICT3734.jpg[/IMG]
You'll see 3 solder connections behind the scre in an "L" configuration. One of them is common, one volume and one power on. As I don't need volume, I'm happy with it being on full as my cinema system will vary the input, I joined all 3 together giving power on and full volume. It is working great now.
[IMG]http://i134.photobucket.com/albums/q116/mm0dxc/PICT3737.jpg[/IMG]
For you guys with volume controls, I would suggest shorting out the two rightmost pins in the "L" and I recon this will power it up and try varying your volume control. I recon it'll work just great.
Good luck
Posted on Jan 22, 2009
nitantsoni
nitantsoni
SOURCE: Altec Lansing ATP3 broken speaker wire ORANGE connector/jack.
Here you go
Posted on Aug 27, 2012
My altec Lansing dock charger and speaker is no longer charging my I pad, but the speaker is working. Is there anything I can do to fix that?
Often dust and larger particles collect on the contacts of the charger connection. Check your ipad charging slot and try using a Qtip or a cloth to clean the AL connector. Be sure to turn the speakers off and disconnect from AC voltage at the wall.
1helpful
I had ordered an altec lansing 1220 speakers from flipkart. While i plugged in the speakers there was no power input to the system....hence it didn't work...when I checked on altec lansing website it...
This speaker is using a USB to draw its power. You can try using other USB ports on the computer or use USB chargers (Apple, HTC, Android phones, etc) to test it, if all else fail then you may need to return it because its defective.
I plugged my 110 volts Altec Lansing speakers into 220 volts :( How can I fix it? Please help me. Thank You.
Check fuse, but if there wasn't a fuse , your Altec need repaired to fix broken components in power circuits, could be the resistors, diodes or even transformer.
1helpful
Need advice on Altec Lansing x5021
Altec Lansing is the best company to buy speakers if you watch movies or listen to music. it hits both deep and a strong bass. These are the best speakers to buy.
No sound after i buy new PC ( speaker altec lansing atp3) should i install altec driver ?
check the port to which u have connected ur speakers. And also install proper driver
Altec VS4221 not working with Gateway
I am guessing that the speakers our connected to the input port.. make sure it not plug on the input port...
Top Altec Lansing Audio Players & Recorders Experts
Ekse
 Francisco Mauricio...
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
