Question about HP Photosmart C6180 All-In-One InkJet Printer
Error 0xc05d1281 keeps appearing, I can't print, scan nor copy
Posted by Rocio Flores on
5 Related Answers
STP162
Sandy Chamberlain
  • 132 Answers
SOURCE: HP 3310 All In One Error
Try to reset the system by holding down the OK, Cancel, Black, and Color buttons at the same time and turn the 3310 off. Keep holding the buttons down until the printer shuts off and then turns itself back on. You will have to turn the printer off twice and then it will recalibrate. Make sure you have new cartridges in the printer so that it can reset.
Posted on Nov 01, 2007
computafixa
Alexander Selby
  • 317 Answers
SOURCE: error code: 0xd0620230
Make sure that you have the latest firmware, hardware and drive updates downloaded and installed from HP. Next, try uninstalling the printer ans the software that came with it. THen reinstall everything according to the manual.
Posted on Feb 23, 2008
leroyal
Leroy Elliott
  • 2120 Answers
SOURCE: can't print, copy, fax, or scan
Uneconomical to get repaired. Sorry
Posted on Jan 28, 2009
Buddy Mcsparrin
  • 1684 Answers
SOURCE: display says error 0xc05d1281
The "Ink System Failure" error is causes by air in the ink feed tubes. We have a step by step guide purging the air from the feed tubes posted on our web site. Go to our site at: www.ccl-la.com , click on the printer repair link and then the HP link. Follow the steps and you should be back printing in no time at all.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Jan 03, 2010
SmartFix
SmartFix
  • 89 Answers
SOURCE: Cannot print, scan or copy. Continue to receive
Solution
  1. Remove and then reinsert the cartridge indicated in the error message.
  2. If the error is still displayed, clean the contacts. Click here to see how.
  3. If the error message is Error. Remove and Check Black or Photo Cartridge , the following steps may help:
    1. Remove both cartridges, lower the latches, and close the printer access door.
    2. Turn off the unit by pressing the On button on the front panel. Wait for the printer to completely shut down.
    3. Turn the printer back on by pressing the On button.
    4. When the message display reads Insert Print Cartridges , open the access door and replace the cartridges.
  4. If neither of the steps above fixed the problem, either the cartridge or the printer is faulty.5. Replace Cartridge.Please rate my response!!!Thanks,SF
Posted on Jan 28, 2010
How do I fix a printing problem where the error message load tray 1 keeps appearing?
You Really need to have this Machine Cleaned. there is too Much Paper dust On the sensor
Jun 06, 2015 | Xerox 6505/dn Workcenter 6505dn Color...
I have error code 0xc05d1281 what does this mean?
This error means "Ink System Failure"
And it means that something went wrong in the ink manager internal printer software.
Try removing all the ink cartridges and then power off and on again the printer
If it asks for inserting the cartridges insert them one by one and see if the error appears, in that case the thing that provoke that error is that specific ink cartridge.
So change the specified ink cartridge.
If you didn't solve with this procedure maybe the printhead failed to do a specified operation, or anyway the printer have a specific error on the mainboard and need assistance
Let me know ;)
ADCSFXworks Printing Center
Mar 10, 2015 | Office Equipment & Supplies
Bizhub C652 has horizontal lines.
its important to find out whether the \'lines\' are in scan direction/ or only through Radf or only from scan glass,
if the lines are only showing when documents are fed throught the Radf, then the problem lies with the document scan plate( left of the main glass platen (about 2" in width)) or with the scan plate blade cleaner
if the lines ONLY appear when copying from the Glass then the issue lies within the optics (probably nothing more than a clean will be needed)
another question would be to ask if the lines are solid (black line overprinting image) or if they are \'missing\' lines where the image has failed to copy, sometimes it can be hard to work out which side the fault lies,so try shaded greys as a copy original .
if the scan lines are appearing on both Radf and Glassplatten ,mode then the issue may be dirty optics/ccd sensor or it could e an indication of the ccd failing or image control pwb in error while interpreting the image file.
what to do
1) place a grey sheet of paper in the Radf and have the copier photocopy both sides of the original and print to single sided sheets ( so the printer turns the original over to complete the task)
observe the result.
2) have the copier photocopy directly from the platten glass- single sided.
observe the result.
ckeck to see if the error has appeared on both sets of prints ,
if the error has only appeared in the first set of prints then the issue may be a tiny DOT on the slit glass (left of platten) - a dot on this glass will indeed appear as a Line as the original is scanned across the glass.
hhope thhis helps
Feb 19, 2014 | Konica Minolta Bizhub C652 Color&b/w...
HPPhotosmart 3210 AIO hangs us with error code of 0xc05d1281
Hi Minnie,
This could be because of residue on the Printhead electrical contacts
Try the steps below and it should help.
Turn off the Printer.
1. Open the Carriage access door.
2. Remove the Cartridges
4. Move the carriage from left to right 6 times and it should move freely
5. Clean the contacts on the Cartridge with lint free cloth. ( Golden dots )
6. Turn on the printer and it should say " Cartridge missing or need to be reinstalled "
7. Install the Cartridges and close the Carriage door
8. the printer should go through alignment process
If this step does not fix, You may try calling HP customer support to check for better options/solutions
HP Customer Care : 1-800-474-6836
Regards,
Sean
Feb 16, 2013 | HP Photosmart 3210 All-In-One InkJet...
LSU Error keeps showing
LSU stands for Laser Scanner Unit. Depending on the model this should come up only if the services used required scanning such as copy, fax sending, scanning.
nevertheless if this is a continuous message you might need to check the connectors within the scanner which I advise an field call.
Apr 30, 2010 | Xerox WorkCentre M20i All-In-One Laser...
Display says error 0xc05d1281
Buddy
Corporate Computer
www.ccl-la.com
Jan 03, 2010 | HP Photosmart C5180 All-In-One InkJet...
Will not scan, copy or print error code e7-11
Replace the Mother Pwb the part number is CPWBN1460DS51..... Good Luck
Jun 02, 2009 | Sharp AR-M350N Copier
Ink failure
put ink cartridges in the printer
Jul 20, 2017 | HP Photosmart C7280 Laser Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
142 people viewed this question
Ekse
efs_perpends
efs_perpends
