Printer in error state
One of the most common reasons as to why microlines wont print is because they are in an error state. 1st thing to check is that the cover you look through has not closed properly on the right side. there is a switch and sometimes its not obvious the cover is slightly open. 2nd Is the ribbon free to turn and located correctly. 3rd Is the paper selector lever in the right position (rear feed/front feed)? Disconnect from the pc and see if you can print a config sheet. Reconnect and see if alarm comes on again.
Need more info. is it hooked up usb or parallel? Are you printing from windows or like an AS400 or OS X. What error is the alarm light blinking or just stays on?.
