Question about Samsung Dishwashers
My Samsung Dishwasher, model DMR78AH5 will not run. The heavy, delicate, quick and smart lights are permanently on. I cut off the breaker for one minute but that did nothing.
Tech support said turn off power for one minute. That did nothing. Lights are not blinking, just on always.
Posted by Fred Youngman on
Claude Kayser
    Top Expert:
  • Samsung Master
  • 9,098 Answers
How to Fix a Dishwasher That Won't Start ' Dishwasher Repair
www.partselect.com/Repair/Dishwasher/Will-Not-Start/
If your dishwasher won't start the problem could be the door latch or door latch ... On manual timer models the timer is used to supply power to the pump motor, ...Missing: samsung ‎dmr78ah5
Samsung Dishwasher Won't Start - Model DMR57LFS ...
www.repairclinic.com/...Dishwasher/...-/Samsung-Dishwasher-won-t-start...
The door latch ensures that the dishwasher door latches shut. If the door does notlatch properly, the door switch might prevent the dishwasher from running.
What to Do When the Dishwasher Won't Start - YouTube
? 5:43
https://www.youtube.com/watch?v=L-bMqVb9kX0
Aug 15, 2013 - Uploaded by doityourselfstan
The problem could simply be a blown thermal fuse inside the control panel. ... Maytag Dishwasher Repair ...
Posted on Dec 16, 2015
I have 3blinking lights on a Samsung dishwasher DW9733LRABB/AA the normal,heavy, and smart auto
Dishwasher Heavy Error Code Repair Samsung - YouTube
? 2:24
https://www.youtube.com/watch?v=uLoj9TpqVRM
Aug 14, 2014 - Uploaded by JoeBrownToolGuy
Dishwasher error code "Heavy" flashing light. Samsung Model DMT400. Video shows what you need to do ...
Nov 23, 2015 | Samsung Dishwashers
Samsung dishwasher heavy and delicate lights blink and cycle stops
The lights that are blinking are indicating an error code--the particular code you describe is a "heater error". You will have to check the circuit for an open heater element, loose or broken wire, defective main control board. The part number for the main board is DE92-02256C. Hope I helped you!
Aug 07, 2015 | Samsung DMT400RHS Builtin Dishwasher
What causes a Samsung dishwasher to flash heavy and smart auto on control panel
Hello. The lights you describe are an error code that means over-level filling (overflow condition) and/or the leakage sensor underneath has detected water. You need to check underneath the unit for any moisture. There is a leakage sensor located at the center of the base, underneath the unit. If it detects water, it will notify the main board which will stop the unit until the condition is cleared.
Aug 02, 2015 | Samsung Dishwashers
Samsung dishwasher fills and drains repeatedly
I would check the drain itself. Make sure there aren't any eating utensils getting caught in the drain area.
Jun 01, 2015 | Samsung Dishwashers
My Samsung Dishwasher keeps flipping cycles during the course of its run. I set it to "normal" and it ends up on "delicate". Dishes seem to be clean, but are still wet after the 2 hour run time. Help...
I'll bet that Delicate light is flashing, which is actually indicating an error. You didn't mention your model number, but in most Samsung dishwashers I'm familiar with, that light indicates a Drain Error. You may have something hard caught in the impeller of your drain pump, or you might have a bad ECS sensor. In any case, it's time to call a dishwasher repair technician. For Samsung dishwashers, I recommend calling Sears Service (1-800-4MY-HOME or 1-800-469-4663).
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Dec 26, 2014 | Samsung Dishwashers
Normal, heavy, delicate lights stuck on--cant power on or off
If you have tried to unplug from mains power and there is no difference then you will need to provide the actual model number of your dishwasher in comments field.
The Samsung error codes for Normal, Heavy , Delicate lights stuck is not listed. The closest is Normal, Heavy, Quick which relates to a Low Water level. Also confirm which lights are stuck in your case and whether these are flashing or not.
Apr 17, 2014 | Samsung Dishwashers
Heavy and delicate light flashing
please provide model number of dishwasher
Apr 18, 2013 | Samsung Dishwashers
Samsung dishwasher wont run; delicate cycle light blinking
see this causes and fix it. God bless you
1. No power to the dishwasher
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer
Replace if defective (note: uncommon problem).
4. Selector switch
5( test the main board can be faulty and replace.
Oct 02, 2012 | Samsung DMT400RHS Dishwashers : Built in...
All my lights on the front of the dishwasher are blinking at me & stops running after 3 minutes into the cycle. What is the cause of this & of course, I am two months past my warranty. Help.
If three lights are blinking (normal, heavy, quick)... I just had this same problem, and I think I figured it out. There was water on the bottom from the last cycle, so I pressed HEAVY and DELICATE at the same time for 3 seconds (you'll see it printed on the control panel), and the unit drained. I was then able to start the new cycle normally without the error. Hope that helps!
Jan 27, 2012 | Samsung DMT300RFW Builtin Dishwasher
Dishwashers Logo
500 people viewed this question
Top Samsung Dishwashers Experts
Dale Copeland
Dale Copeland
gbob59
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
