Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
Copy Problems HiWhen i move files that are 700MB it's fine, but when i try to move large files like 5 Gig it doesn't let me and says that disk is full when i have over 170 gig free space.Any ideas? thanks in advance
Posted by Jimbo_1007 on
  • 2 more comments
  • Jimbo_1007 Nov 18, 2007
    Thanks guys.. That explains the problem for me. I guess i'll have to format it
  • stjeantim Nov 18, 2008
    i have exactly the same problem so im assuming most people format to ntfs otherwise there is no way of being able to back up video files of good quality.how exactly is it a problem when changing to ntfs?is fat 32 therefore a more reliable format?and what is equally worrying is the fact that there is so many people posting problems with these drives that it makes me feel like backing up my data onto dvd..getting a hard drive was meant to free up space and offer me a secure storage facility now i dont know.various people are also saying that by changing to ntfs you will lose all your data and others are saying you wont is there anyone out there who actually knows definatively? thanks
  • Anonymous May 18, 2009
    Identical problem, but the reformatting doesn't work if it is still FAT32.
  • Anonymous May 24, 2009
    ahhhhhh!! that is so lame!!!
Anonymous
    Problem Solver:
  • 10 Answers
It's not a question of re-formating...It's a question of Partition...FAT32 does not allow files over 4gb to be stored...You have to convert the partition to NTFS..There are tools for that on the WD website....Try to do some research about the pros & Cons of NTFS..because you wont be able to go back to FAT32 without formating....
Posted on Nov 18, 2007
Anonymous
    Scholar:
  • 86 Answers
I have seen this problem 3 times before. There was only one solution, and it worked all 3 times. Reformat the Drive and it will work properly. When you do this, you will loose all data on the drive, so make sure you back it up.
Posted on Nov 17, 2007
Keeps freezing start up
Around 4 gb ?
In the Microsoft Windows operating system, you can copy and paste 5 GB files as long as you have enough disk drive space.
The disk drive to which you're pasting the file must be formatted using the New Technology File System (NTFS), which supports the copying and pasting of very large files.
Purchase a large capacity USB external hard disk drive from a reputable vendor.
Make sure that the hard disk drive is at least 100 GB.
Connect the external hard disk drive to a spare USB port in your computer. Wait for the Windows operating system to recognize the hard disk drive.
Double-click on the "Computer" icon on the Windows Desktop, after which a window will appear listing all of your disk drives. Establish the letter of the new hard disk drive you have just installed. For the purpose of this article, the drive letter is assumed to be "E."
Right-click on drive "E," click on "Format," change the file system to "NTFS," then click on the "Start" button. Wait for the process to complete.
Click on the 5 GB+ file to select it, then press "Ctrl" + "C" on your keyboard to copy the file to the Windows Clipboard.
Click on the "Computer" icon on the Windows Desktop, then double-click on the "E" drive. This will open the root folder of the hard disk drive in the same window.
Press "Ctrl" + "V" on your keyboard to paste the 5 GB+ file from the Windows Clipboard to the new hard disk drive. Wait for the process to complete, which will take several minutes.
File transfer software
http://www.filebuzz.com/findsoftware/High_Speed_File_Transfer/1.html
http://download.cnet.com/Fast-File-Saw-Joiner/3000-2248_4-10388628.html
When e-mailing or archiving huge files, it sometimes helps to cut them into smaller pieces.
Fast File Saw & Joiner does exactly that, and puts the pieces back together, too.
Dec 12, 2013 | Iomega Computers & Internet
Can't copy large files onto my external harddrive
What format is the external drive ?
you might need to split the file with rar
I recently downloaded win 8 5gb had it split with rar into 2 files downloaded with IDM trial
The FAT32 format does not support single files larger than 5GB, so if you have a file larger than 5GB you cannot put it on your FAT32 thumb drive. Most thumb drives and other portable media devices use FAT32 format, so this setback makes large files less portable, and that just won't do. Get around this problem by compressing the of the file or by splitting the file up into multiple pieces.
Create a folder for your RAR file and insert a copy of the original file into this folder. RARing a file separates it into multiple pieces, so creating a file specifically for your RAR file will keep the files together allowing you to move one folder to your FAT32 device instead of having to locate and move multiple files. Right click the large file that you want to put on a FAT32 device. Select "Add to archive" from the menu that appears to the side. Select "RAR" from the "Archive Format" located to the left of the menu. Click the arrow next to "Split by volume, bytes," and select "CD 700: 700mb." This will create a new file for every 700mbs, meaning your your one large file will be separated into many 700mb files that can be put back together as a single file later. Click "OK." Put the folder, containing your newly separated files, onto your FAT32 device after WinRAR has finished separating the file. b> Zip File b> Right click the large file you want to put on a FAT32 device. Select "Add to archive" from the menu that appears to the side of the file. Click "OK" on the next menu. This menu allows you to customize the compression settings. The only option you need to change is the "RAR" selection to "ZIP" in the "Archive Format." The rest of the default settings will work fine, so there's no need to change anything else. The zipped file will appear in the same folder as the original. Delete the copy of the original large file from the folder and put your newly compressed file on your FAT32 device after the file has completely compressed. The time it takes for the file to finish compressing depends on the of the file. Hope this helps. http://www.all-freeware.com/getfreeware.html?pid=109090&mirror=1
b>
Jan 08, 2013 | SmartDisk 250GB SMARTDISK CROSSFIRE EXT...
USB flash
What format is the drive
In the Microsoft Windows operating system, you can copy and paste 5 GB files as long as you have enough disk drive space. The disk drive to which you're pasting the file must be formatted using the New Technology File System (NTFS), which supports the copying and pasting of very large files.
Purchase a large capacity USB external hard disk drive from a reputable vendor. Make sure that the hard disk drive is at least 100 GB. Connect the external hard disk drive to a spare USB port in your computer. Wait for the Windows operating system to recognize the hard disk drive. Double-click on the "Computer" icon on the Windows Desktop, after which a window will appear listing all of your disk drives. Establish the letter of the new hard disk drive you have just installed. For the purpose of this article, the drive letter is assumed to be "E." Right-click on drive "E," click on "Format," change the file system to "NTFS," then click on the "Start" button. Wait for the process to complete. Click on the 5 GB+ file to select it, then press "Ctrl" + "C" on your keyboard to copy the file to the Windows Clipboard. Click on the "Computer" icon on the Windows Desktop, then double-click on the "E" drive. This will open the root folder of the hard disk drive in the same window. Press "Ctrl" + "V" on your keyboard to paste the 5 GB+ file from the Windows Clipboard to the new hard disk drive. Wait for the process to complete, which will take several minutes.
File transfer software http://www.filebuzz.com/findsoftware/High_Speed_File_Transfer/1.html http://download.cnet.com/Fast-File-Saw-Joiner/3000-2248_4-10388628.html When e-mailing or archiving huge files, it sometimes helps to cut them into smaller pieces. Fast File Saw & Joiner does exactly that, and puts the pieces back together, too.
Nov 26, 2012 | Kingston Digital DataTraveler 4000 8 GB...
I have a 2 gig card that won't let you use that amount of room
Reformat he frame's internal memory.
1. Click on the "Macintosh HD" icon.
2. Click on "Applications".
3. Click on "Utilities".
4. Click on "Disk Utility".
5. "Kodak" drive should be in the list showing a white drive icon
6. Click that icon and select “Erase”.
7. Select the “MS-DOS file system (FAT16)” option and give it a volume name e.g. "Kodak". The format will begin when you click the “Erase” button below.
8. Try to copy the files to the re-formatted internal memory of the frame.
Dec 28, 2009 | Kodak EasyShare C315 Digital Camera
Can't copy files to drive. Says disk is full and it is not.
what filing systems do the passport drives use and how large are each of the files ?
If they are fat 32 and the files are each larger then 4gb then that is why it will not work as fat32 does not support or allow more then 4gb per file due to the filing system so you would need to format it as NTFS if you want to store files larger then 4 gigs
Apr 14, 2009 | Computers & Internet
I have an acer 5000 laptop with an 80 gig hard drive which is partitioned into a C and D drive.  the C drive is now full and i am concerned that it i make the D drive the active drive i will not be able...
Partitions are seen by the computer as separate drives. When you try to move files by dragging and dropping, the default action is to copy, not move. So--you will have to actually delete them from the C partition if you copy them to the C partition.
I have no idea why Acer does this. When I come on to a problem like this, I usually combine the partitions with a utility such as Partition Magic.
Don't try to make the D partition bootable You won't like the result.
Try, instead, to move your data files over there. Just remember, when you save docs, be sure they are being saved to D and not C.
Hope this helps.
Jan 29, 2009 | Acer Aspire 5002WLMi Notebook
Transferring to another notebook HDD and finding problems
did you copy your operation system onto your new hard drive? Must of the time they a hidden file that the manufacture does not want you to find. If you did the you may have to go to your bios and make sure that it's set to boot from your e dr1ive first because that 's where the operating system is on.
Dec 22, 2008 | Computers & Internet
External hard drive disk space
Hi
Is it showing the 300gig in the properties? if yes then try to copy with command mode,If again its given problem then u need to backup your data and format the drive, then try copying.I think it will work.
T.Boopathy
Aug 17, 2008 | Western Digital My Book Essential Edition...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
297 people viewed this question
Top Western Digital Computers & Internet Experts
Ekse
ChinthakaJ
ChinthakaJ
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
