Oven lights but then flame goes out as soon as I release the knob
I can't get the oven to stay lit - when I push the knob in and rotate to light, I see and hear the oven ignite. It stays lit until I release the knob but then immediately goes out. It seems like a safety feature is malfunctioning.
Yes, pilot light sensor needs replacing or see if you can move it closer to the pilot flame, sometimes it can work as the pilot flame throw can become shorter from original factory throw over timeYes, pilot light sensor needs replacing or see if you can move it closer to the pilot flame, sometimes it can work as the pilot flame throw can become shorter from original factory throw over time
You can't post conmments that contain an email address.
Mar 18, 2008 - Similar Questions: light pilot stays till release button suggestions ... If you have held it for a long time and it still won't stay lit, then your thermocouple is bad.... the gas valve doesn't think a flame is burning the gas coming out of the pilot ... less likely but somewhat common is the gasvalve... if the knob you are ...
I had this same issue on this same model (which is how I happened upon this page). I'm still not exactly sure why, but the problem resolved when I pushed down on the knob more firmly than I normally would to light the stove, and it seemed to slide in a little deeper. After that, the oven would light.
While your holding in the knob after lighting the pilot,their is a thermocoupler that is heating up and will hold automatically what your pushing in, that thermocoupler is defective
Right above your pilot light, there is a little temperature probe. It either needs to be cleaned, replaced, or adjusted closer to the top of the pilot flame. Hope this helps. Good luck!
Some of the models require you to push in the oven thermostat knob to set the pilot if it blows out. So try pushing in the knob and hold it while lighting the pilot. When the pilot lights continue to hold the knob in for about a minute. When you let go of the knob the pilot should stay lit. If it does not stay lit then try it one more time. If it continues to go out the thermocouple or aso might be bad and will need service.
I'll give this a go!
With a cooker like this, you depress and then turn the control knob, press the ignition button and continue to depress the control knob for a few seconds. This is because a device called a thermocouple is heated by the flame and you have to continue to depress the control knob so that sufficient gas flows to heat up the thermocouple. If the thermocouple does not get hot or stay hot then the gas valve is automatically closed - stopping the gas. The thermocouple is a 'flame failure' safety device. If the gas gets cut off then the flame goes out and the thermocouple goes cold switching off the gas valve automatically.
However, you are having to try and manually keep the gas going for a good five minutes.
I would think that there is either a problem with the thermocouple or the gas control valve!
Tony
www.birminghamelectricsltd.com
Yes very simple. There is a bulb the flame is heating with a small tube that runs to the gas valve this is the saftey sensor that is bad called a thermo-couple , they are common to go out and should be easy to find online. Let me know if you have any other questions.
Phil
I have the same problem with a back burner
