Question about Bushnell BackTrack Handheld GPS Receiver
I can't get the cover off to remove the batteries.
Posted by Walt on
How do i remove battery off of a Samsung Galaxy j7
Choose free 2-day shipping or in-store pickup.
Sign in
Home Support Samsung Galaxy J7 / J7 V Samsung Galaxy J7 V / Galaxy J7 - Remove Battery
Ensure the device is powered off.
Remove the battery cover.
Note With the device facing down, utilize the provided slot (right-edge), carefully lift then detach the cover.
Remove battery cover
Utilizing the notch in the lower-left corner, lift, then remove the battery.
Note If applicable, refer to Insert the Battery.
Remove battery
Replace the battery cover.
Replace battery cover
Press in on the cover to lock it into place.
Find the cmoss battery d505
Unplug the Dell Latitude D505 laptop from AC power. Turn over the so that the base of the computer faces upward. Locate the battery panel on the bottom of the computer and then press the latch on the battery panel in the direction of the arrow on the latch. Lift the battery from the battery compartment.
Press on the latch located toward the front of the computer inside the battery compartment. Pull the cover that is released out and down and remove the cover from the battery compartment.
Grasp the small battery in the slot uncovered when the cover was removed and pull the battery away from the slot to detach the battery from the laptop
4helpful
Replacing battery on Aston Martin Vanquish
Below is the procedure for an Aston Martin Vantage, perhaps the vanquish is similar?
Removal
1. Power the driver's fully forward.
2. Remove rear compartment cover.
3. Loosen and disconnect battery terminals, earth (- ve)
terminal first.
4. Release rear carpet, studs (x2), move carpet aside.
5. Remove screws (x2), battery compartment cover to
support rail.
6. Remove nuts (x2), battery compartment cover to body.
Remove cover.
7. Remove Torx screws (x4), remove battery clamps (x2).
8. Disconnect battery vent tube.
9. With assistance, remove battery.
Installation
1. Clean battery tray and clamps.
2. With assistance, install battery into its compartment.
3. Connect battery vent tube.
4. Position battery clamps (x2), install and torque tighten
Torx screws (x4).
5. Ensure battery vent tube is not distorted by battery.
6. Install battery terminals, tighten terminal nuts to correct
torque.
7. Install battery compartment cover, install and tighten
screws (x2) and nuts (x2).
8. Position rear carpet, secure with studs.
9. Install rear compartment cover.
10. Reposition driver's seat.
Courtesy of pistonheads.com
Please vote if this helps! Thanks, Mike
I'm trying to clear the memory on my Ti-84 Plus, but every time I hit 2nd then + to access the memory, nothing happens. It doesn't take me to the screen or anything. It justs stays on the blank screen.
  1. Power of device.
  2. Remove primary battery cover.
  3. Completely remove all 4 AA batteries.
  4. Unscrew and remove back up battery cover.
  5. Remove all back up batteries.
  6. Wait 60 seconds.
  7. Reinsert back up batteries and cover.
  8. Reinsert all 4 AA batteries and cover.
  9. Power on device.
  10. Memory cleared!
My HTC Hero is frozen, is there a way to take the battery out?
Hi. Remove the battery cover then you can remove the battery. Here's how to remove the battery cover:
http://michaelquale.com/911134/how-to-remove-the-battery-cover-on-the-htc-hero/
How do I remove the battery on my "04 v star custom
Remove cover panel. Disconnect posotive and negative wires if possible without removing battery cover. Remove battery cover and pull battery out towards you and up.
How do you open battery slot
(1)Remove the USB connector cover.
(2)Press and Move the battery cover in the direction of the arrow.
(3)Remove the battery cover and insert one AAA-size battery into the
(4)Replace the battery cover.
How to remove the battery door from my sidekick II
1. Turn your device off and remove the battery cover and battery
2. Remove the end-cover by pushing the cover away
3. Pull the bumper tabs up to separate the bumper from the device and remove bumpers
4. Snap new bumpers firmly into place
5. Re-attach the end-cover, re-insert the battery and re-attach battery cover
Got a new samsung j700 today but i cnnot remove the battery cover I bought a new Samsung behold cell phone today and can't remove the battery cover on the phone.
Remove the battery cover. To do so, press the ridged area on the battery cover using your thumb (1) and gently slide it in the direction of the arrow (2). Remove the battery cover.
Place the battery so that the three brass tabs on the end align with the three brass prongs at the bottom of the battery compartment (1). Press the battery down until it clicks into place (2).
Replace the battery cover. Make sure that the battery is properly installed before switching on the handset.
Thanks.
Bushnell BackTrack Handheld GPS Receiver Logo
Top Bushnell GPS Experts
ADMIN Canada
ADMIN Canada
Tom Chichester
Are you a Bushnell GPS Expert? Answer questions, earn points and help others
