The tv had no power at all. I replaced the power supply boards now I have a flashing standby light that flashes 3 times but that is all the tv does. The digital fiber optics input lights up red. I have tried holding down the power button and menu button at the same time without any effect. The yellow standby light flashes 3 times then pauses then flashes 3 times again each time I push the power button. Any help????
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
B+ over voltage protection (OVP), unit goes to the standby mode then
displays the 3 blink fault. This is also a problem in the power
supply circuit, check T603 and R672.
Have you set the output voltage correctly?
