Question about Jura Capresso Impressa F7 Espresso Machine
My impresses 7 says empty grounds - but everything has been emptied and cleaned and it still won't reset. What do I do next?
I have even unplugged it vacuumed it out.
Posted by Sharon Harapiak on
2 Related Answers
RB5193
  • 4 Answers
SOURCE: impressa z5 grounds empty will not reset even
If the machine says TRAY MISSING it's the contacts at the back so clean as other people have stated, you can also use a cardboard nail file to clean the contacts at the back if there really skanky!.
If the machine keeps saying EMPTY GROUNDS even though you have, pull out the tray, look just inside the aparture where the tray goes top right at the front there is a small slot where if you look closely you can see a small white micro switch. This will be probably gunged up with coffee and the switch will be stuck up, get a can of WD40 and squirt a small amount up into the switch then poke the switch with a small screwdriver up and down until it moves smoothly.
Then replace all the bits, sit down, look smug and have a coffee cos you've fixed it!! :0)
Posted on Oct 13, 2009
Anonymous
SOURCE: EMPTY GROUNDS warning will not reset
The solution was referenced in one of the earlier postings but I wanted to clarify in case people are misunderstanding. The two metal contacts at the back of the machine insert into the wall of the machine and tell the coffee maker that the tray is inserted. Sometimes the big, flat, readily visible portion of these contacts get dirty and I think people are focusing on this portion of the contacts. However, the metal contacts also bend down into the tray where they can detect water (basically if there is enough water or material to conduct between the two contacts then the machine tells you to empty the try). This is the portion where you need to focus on cleaning, down in the tray, between the narrow plastic valley at the back of the tray. It will require Q-tips or something to really push down into the tray to clean away from the contacts. I did not have water in the tray but had enough moist old coffee grounds that it was causing the issue. I cleaned this area with water, a toothbrush and Q-tips and ensured it was very clean and dry. I have not seen the issue again in months (my coffee maker is three years old, gets used daily and we keep it relatively clean, but this is the first time we've gotten this error).
Posted on Jun 26, 2010
I have the shark rotator vacuum and the brushes won't spin
Hello again Lois Victor,
Make and model number always help... Thanks.
If you don't have your manual...
find them FREE at
Shark NV750ANZ Owner Manual
or here..
Shark Rotator NV752 Owner Manual
or by going to
http://poweredliftaway.com/
AGAIN... hope this helps
Carnac the Magnificent
Jan 10, 2018 | Shark Vacuums
Dirt isn't coming up into the canister even though the rug looks cleaner.How can I fix?
Sounds like a clogged hose. Try running a coathanger or other stiff wire into the hose. UNPLUG the vacuum first! A small hook on the end of the wire helps pull clogs and prevent hose punctures.
May 08, 2015 | Vacuums
Waste gate on my 99 7.3 is not getting enough vacume what can cause this?
Sounds like vacuum leak anywhere in the system. Check all hoses and even brake booster for leaks. Use a vacuum gauge if you have one.
Dec 12, 2014 | Cars & Trucks
Empty Tray
Hi all, I have the exactly same problem on my Gaggenau CM470 however the drip tray is clean and the contacts in the back is also 100% clean.. I wonder if its possible to disable the sensor/switch on a CM470 ?
Aug 04, 2013 | Jura Capresso C3000 Espresso & Coffee...
Ricoh aficio 2105 waste toner full indicates even if it was already empty, cleaned the bottle sensors still indicates full, how am i going to reset it?
Make sure the 2 waste toner are empty.
You have 2 bottles of waste.
1- Next the papaer trays
2- Next the development Unit
May 25, 2011 | Ricoh Aficio 2015 Copier
When plugged in the hose light blinks
My spotbot lights would blink and it, for a time, only worked on deep clean even after unplugging and plugging back in. Finally it wouldn't work at all, only the hose light would blink. I unplugged the hose and plugged it back in and the machine started working as it should.
Apr 10, 2011 | Bissell SpotBot Robotic Wet/Dry Vacuum
The power brush does not work.. How do I get at the belt to check it
There should be tabs holding the skid plate cover in. Turn the tabs, and the cover should un-hinge.
--W/D--
Jan 21, 2011 | Electrolux Epic 3500 Vacuum
Jura Capresso Impressa F7 Espresso Machine Logo
224 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
markybean
Level 1 Expert
ThaMp3Doctor
ThaMp3Doctor
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
