Question about Carrier Heating & Cooling
I have a Carrier Debonair 450 Thermostat. The back-light of the LCD screen does not work. Neither do the buttons for the thermostat glow red or blue respectively. What could be causing this problem?
I have four of these thermostats. I have owned them for 4 years. The lights on them stopped working about 2 years ago in succession. One stopped then at a different date another and so on and so on. Is there a replacement light bulb?? the thermostats still work but when all the lights are out I cant see what the settings are on the thermostats so I have to open a light or use my phone to check them. Its just annoying.
Posted by Vasili Piperis on
scot
    New Friend:
    Problem Solver:
  • 14 Answers
The t-stat needs a common and a hot. I know that is simple but it doesn't hurt to ask. Do you have the 24 volts needed to operate the t-stat? If you have 18 volts that may affect the lights.
Posted on Jan 16, 2016
5 Related Answers
Anonymous
  • 57 Answers
SOURCE: Carrier Furnace wouldn't light, fan was running all the time.
Most furnaces have a photo cell if it gets dirty the photo cell does not see a flame so it trips the reset button on flame failure.
Posted on May 21, 2008
Anonymous
  • 8 Answers
SOURCE: Wiring Hunter Thermostat to 6 wire Carrier fa4bnf036
you probably purchased a 4 wire thermostat which we call heat/cool you stated you have 6 wires which signifies a heat pump you have to purcahase a heat pump thermostat and then write down the color of the wires to there related spots example...yellowe-y red-r white- w and so forth also before you do this kill the power the voltage typical for residential is only 24v's but if the wires touch you could blow a fuse
Posted on Dec 15, 2008
Donni Steen
  • 687 Answers
SOURCE: Rudd furnace
You have a safety limit switch that is either bad or needs to be manually reset. Some have little buttons between the two wires going to the switch that you can push to reset. If not they are automatic switchs then one is bad. You have to do an ohms test to see if each switch is bad or good.
Posted on Jan 05, 2009
Anonymous
  • 614 Answers
SOURCE: blank thermostat
Check voltage at unit. Also check the 5 amp fuse in the unit. If this unit has a float switch in the drain line check that. Rus
Posted on Dec 03, 2009
Anonymous
SOURCE: Carrier Infinity Control Thermostat SYSTXCCUID01-B
Your old stat is wired for a traditional thermostat and not a communication stat like the new infinity you have. There is a module plug on the furnace board that will need to be connected to the new thermostat for it to work. The wires that are wired now are from a terminal strip inside the furnace. Please contact your local Carrier dealer. They may be able to get that harness for you
Posted on Jan 10, 2010
How to clear"service filter"after i changed the filter on Debonair 220 Carrier thermostat
Press mode and program together and hold to enter configuration. Press mode until option 11. 11 is the run time before reminder, put this to 0.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Aug 07, 2017 | Carrier Heating & Cooling
Thermostat wiring on carrier furnace.How to??
you have to go to the furnace and match up the 4wire tstat wires to the thermostat so for instance say
RED-RED 24v
White-White heat
Green-Green fan
Blue-Blue will be Y for cooling
Nov 03, 2016 | Carrier Heating & Cooling
I have a carrier debonair 450 it is blank and not working it does not take batteries. needing help
Carrier Thermostat 33CS450-01 User's Guide ...
homeappliance.manualsonline.com > ... > Carrier Thermostat
Appliance manuals and free pdf instructions. Find the user ... Carrier 33CS450-01 Thermostat User Manual. Page 1 ... Carrier Corporation 04/06. Use with most ...
Sep 10, 2015 | Home
Carrier HVAC thermostat not fully displaying digital read out. Control bottoms doesn't work have to depress really hard and eventually works
Does it have a battery backup in the unit? If so replace them. If its an older model used frequently oil from your hands gets behind the buttons which causes intermittent connections and can cause display error. Remove the unit, carefully open it up and clean all contact surfaces with q-tip and a bit of rubbing alcohol. May solve your problem. While your at it make sure all wire connections are tight. Mark all wire locations during disassembly to make sure they go back in the right place.
Jan 01, 2015 | Carrier Heating & Cooling
Trouble light comes on, can barely read the instruction around it(faded over time)It says to push a red button but not sure where the button is. Help!!
When trouble light comes on, it indicates that the hi-limit is tripped (this happens when oil temperature exceeds 450 Fahrenheit). The red button is located at the upper back panel of the unit, give it a push to reset but if nothing happens after resetting the button, the hi-limit needs to be replaced. Also try to check if the thermostat is working, stuck thermostat's mechanical contact will cause the hi-limit to trip.
May 05, 2011 | Wells F14 Deep Fryer
Blank thermostat
Dec 03, 2009 | Carrier 36KCARMS Air Conditioner
Dec 06, 2007 | Heating & Cooling
Heating & Cooling Logo
371 people viewed this question
Top Carrier Heating & Cooling Experts
Dennis Boxerman
jdthefixer
Marvin
Marvin
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
