Magnavox TV turns itself on and changes channels
Have had this TV for several yrs. and just started turning on by itself and then started flipping thru the channels by itself. I can turn the TV off and after a few seconds will turn itself on and after a short while will start changing channels. I removed the batteries from the remote to eliminate that as a cause. The only way to stop this is to unplug the AC power cord.
Posted by Lar Micheli on
Rani wadia
    Master:
  • 996 Answers
Channel + or - switch is stucked in,,or broken plastic stucked in ,watch thorougly
Posted on Dec 14, 2015
52" rca comes on but flips thru channels and
Try here http://www.consumeraffairs.com/home_electronics/rca.html
Or Try here http://www.google.com/aclk?sa=l
Sep 26, 2011 | RCA Televison & Video
My screen turns off and on... stays off for several seconds and thens turns back on... does this several times, then wont turn back on until I unplug the power cord and replug.??? Unit is about 1.5 yrs...
Before we start taking things apart, lets try your simple remove power plug routine and power system back up. Also, please try your unit on a few different channels to see if your problem continues on each channel. Your Main Board, Power Board, T-Control Board are suspected problems at this time. Press and hold the power button for about 15 seconds, the unit should power down by itself after you have powered it on. If it does not, then do not be concerned. Let me know if the problem continues. The first link below will bring you directly to the troubleshooting guide if you need to continue forward with the same error. Additional information http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums http://en.wikipedia.org/wiki/Capacitor_plague Parts: www.shopjimmy.com
Jan 20, 2011 | Samsung SyncMaster 2233BW 22" LCD Monitor
RCA 2001 P61927
Okay there is something wroung with the frount panel there may be debris in where the button is depressed or seomthing is depressing the button or it may be just going out on you.
1. take off the frount cover and examine the channel up and down make sure its clean and there are no debris.
2. if that does not work replace the controller board aroun $65 bucks.
I do not know your zip code but you can give these folks a shot www.teexp.com you can call and ask how much it would cost to replace this controller even though they might not work in your area they still can give you a price.
Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jul 17, 2009 | RCA P61927 61" Rear Projection Television
Problem with JVC AV-27530 27" TV programing itself...goes through the channels and will not stop.
THESE SETS ARE BAD ABOUT THE KEYS ON THE KEYBOARD STICKING--I POSTED MAYBE A CURE FOR THIS ...READ IT TUNICA
Sep 14, 2008 | JVC AV-27530 27" TV
Flipping channels by itself
are any of the front panel buttons stuck?
Aug 09, 2008 | RCA TruFlat 27F520T 27" TV
Tv turns on by itself
Hey Bubba,
If your TV is turning on by itself at about the same time each day you may have a timer activated, turn it it off, the TV's micro might need too be reset. To reset unplug your TV from the a/c outlet for at least 5 minutes.
Jun 05, 2008 | RCA P52926 52" Rear Projection Television
Powers on by itself
TV worked FINE for the past 2 yrs---this morning we woke up and the screen is totally BLACK! No sound..nothing. REmote doesn't do anything to the TV. Red light says ON unless we unplug it. Remote won't turn off the TV.
Any advise? Picture tube??
Worked great w/out any problems until we woke up today!
Thanks,
Tina
Jun 01, 2008 | RCA 32V420T 32" TV
Televison & Video Logo
919 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
