Hi my tv sounds like it start but it wont como on i change the power board but still did the same what could it be thanks
Posted by Samuel Gonzalez on
Claude Kayser
    Top Expert:
  • 9,098 Answers
Samsung 52" TV Repair - Won't turn on Clicking Sound ...
? 9:37
https://www.youtube.com/watch?v=2WpSJy_kANs
Apr 13, 2012 - Uploaded by Kathy Burton
It makes a clicking sound several times before it turns on, seems to ... Samsung 52" TV Repair - Won't turn on Clicking Sound ...Maybe it took a little longer than that, but I was happy. ... My TVworks like new. ... Samsung No Start / Clicking Repair - 52" LCD HDTV - Duration: 8:26. by clipdan 169,453 views.
TV Will Not Turn On - Troubleshooting Help for Finding ...
? 2:32
https://www.youtube.com/watch?v=kEDVc-BXf0I
May 1, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV that Will Not Turn On - Troubleshooting Tips for finding symptoms and ... hi my tv flashes red and bluebut wont turn on.
Posted on Dec 12, 2015
Seiki TV no picture or sound
hi test the large diodes on the power board these can stop the led from firing up, thanks, ps send me a picture of the power board i'll show you the diodes
shaun
Jun 15, 2017 | Seiki Televison & Video
Samsung PN43D450 Clicking noise
it sounds like its tripping on the power board
one of your boards is faulty
Jun 03, 2014 | Samsung Televison & Video
TV wont power on, SB light shows one flash
hi no sound or picture usually can be down to the mainboard, corrupted firmware, check the capacitors on the psu board for swollen tops, but they don't have t be swollen to be faulty, thanks
shaun
Mar 18, 2017 | Toshiba Televison & Video
RCA D56W20 The power button turns green, does not blink and then goes dark, no picture and no sound,
hi;
this has a problem with power supply section.
when you LCD TV wont start , even if you press the power button , it has a power supply failure, maybe some capacitor ha bloated or change the value, try to watch this http://www.youtube.com if you know how to solder, or even disassemble the back of LCD TV. if not try to call a repair technician. thanks ,, hope this help.........
Sep 05, 2011 | Televison & Video
Hi, Can anyone recognise or diagnose this problem we are having with our Samsung LA32A450 LCD TV? It wont power up, no power on lights. Switch on side of TV wont turn on. Remote wont power it...
hi g_coopster,
Samsung LA32A450 LCD TV wont power up or no power on lights that indicated that no power line.
First of all, check the power line, cable AC cord is it installed properly, change ac cord if necessary. If you experience with electrical tool such as Volt meter, try it to measure the ac voltage from power line.
Or open your rear cover of unit, there are 2 board with difference color brown PCB (IP Board) and Greend PCB (main board). Check fuse on power board, if broken that may cause your problem. Change with the same type as labeled on it. But becareful, if after you change and try plug the power line in than broken again, thats mean power board have sort circuit.
My suggestions, try steps above and if it file, change power PCB block. You can buy it on Samsung cervice center.
Good luck.
Mar 22, 2011 | Samsung LA32A450 32 in. HD-Ready LCD TV
Hello, Im having problems getting a pictur on my screen. The screen stays black but the power button is green so that means the TV is on but it wont show anything.. I also don't hear sound either im not...
hi in a dark room shine a flashlight on the screen see if you see an image, if you can then you may inverter/ power board problem, if you can't you may have mainboard or tcon board problem thanks
shaun
Jun 14, 2017 | LG 32LB4D 32 in. LCD HDTV
Philips 52PFL7422D/37 TV is $2200 piece of junk... cant believe it wont work (no picture no sound) after just over 2yrs... I use to get picture and sound when i played around with the on/off switch...
Yes,it is the power supply board problems.The power supply board,that board where the power a/c cord plug into it.U have all the tools,know basic eletronic and basic soldering?Yes,check the power supply board for those dying parts call capacitors.These capacitors that are dying,it alway will bulges up or puffing up on it tops.By checking the power supply boad and replaced all these dying capacitors,will solved ur tv powering up problems.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Dec 02, 2010 | Philips 52PFL7422D/37 TV
Hi, I have a L32A01 TV. What it does is the red LED comes on then turns into green, something flashes up on the screen, then it goes to red again and starts it again. I'm an electric engineer, so there...
change the electrolytic caps on the power supply board use 105 degree and higher voltage working caps if you can fit them on the board its a common problem the power supply is the overworked part of most tv,s etc
Nov 14, 2017 | Hitachi L32H01 32 in. HD-Ready LCD TV
Sony Projection TV 60 XBR, wont turn on, blinking green light
This sounds like when the power came back on a surge went into your tv and burnt out the TVs main power supply or possibly burn out the flyback power converter on the TV main board!
(I am pretty sure it is either one of these things!)
Please rate answer
THANK YOU!
Jan 15, 2009 | Televison & Video
Televison & Video Logo
342 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
