Question about Kenmore HE5 Electric Dryer
Why won't it start?
MY DRYER DOOR WAS COMING OPENED DURING A DRYING CYCLE, HOWEVER WENT TO BED AND GOT UP AND DRYER WILL NOT WORK. THE DRUM LIGHT WORKS AND IT HAS 220 POWER BUT IT WILL NOT POWER UP. IT HAS NO ERROR SHOWING.. THE SEARS TECH CAME BY AND STATED THAT THE INNER FACE WAS BAD, SO I RECEIVED THE PARTS AND PUT THEM ON AND HAD ANOTHER TECH COME HER THAT WAS NOT FROM SEARS BUT LICENSED AND HE SAYS EVERYTHING IS ON CORRECTLY AND DRYER SHOULD WORK.. SINCE THE THERMAL FUSE IS GOOD.. WHAT SHOULD I DO?
    Top Expert:
  • Kenmore Master
  • 9,098 Answers
Free Kenmore Clothes Dryer User Manuals ' ManualsOnline ...
laundry.manualsonline.com > ... > Laundry Appliance Kenmore
Products 1 - 50 of 65 - Kenmore ELITE HE3 Gas Dryer User's Guide 110.9787 9789. Pages: 0 ... Kenmore 27-Inch Wide Electric Dryer Owners Manual. Pages: 0 ...
Whirlpool & Kenmore Dryer Repair #02 - Won't Start or Run ...? 7:29https://www.youtube.com/watch?v=SPRqKVE8JfYOct 21, 2011 - Uploaded by canyonman1963... and repair a Whirlpool or Kenmore electric dryer that will not start or run. ..... I have a Kenmore Elite Oasis ST Dryer, model number 110.78082701. During ... Dryer Troubleshooting - NotDrying or Taking a Long Time to Dry ...How to take apart Kenmore Elite Dryer - YouTube? 6:28https://www.youtube.com/watch?v=QNa6zfzrm5kOct 16, 2012 - Uploaded by RenewApplianceI have a kenmore elite 79661423410 electric dryer stoppedworking manual says has no thermal fuse and I can't take it apart help thank you.
Posted on Dec 12, 2015
Anonymous
SOURCE:
Anonymous
  • 290 Answers
SOURCE: Kenmore 62822 electric dryer
Check your heating element to see if it is shorted to ground.
The element has 110V to it all the time, so if the element shorts to ground it will heat all the time. This is a fairly common failure.
If the element is ok, you may have a stuck centrifigul switch inside the motor, this is very rare but does happen sometimes.
Post back to let me know what you find or if you have any questions.
Thanks/Mike
Posted on Dec 20, 2007
Master_Tech
Gary Davd
  • 770 Answers
SOURCE: HE4 Elite dryer beeps
The Thermal fuse is most likely the problem.
Posted on Jan 26, 2008
buglette
SOURCE: Kemore Elite Oasis Dryer Error Code "AF?"
Problem solved! We read on here about someone else addressing the AF code by removing the back panel and fixing the pully that had come off. Belt was fine, with pully back in place dryer now works perfectly again. Thank you for saving us so much time and money!
Posted on Jun 14, 2008
Anonymous
  • 261 Answers
SOURCE: Kenmore Elite Oasis Electric Dryer
These are awesome solutions, L1 or the black hot wire supplies the lights and one leg of the heater while L2 the red power wire completes the circuit for the heater and powers the board. A great test is this, if the light is on and the load doesnt go, bad load. In this case trace the L2 line and find where the power stops, the first is the interface and the same goes for Frigidaire. I would also get the part number from Sears, tell them you will wait for money and then look for other local sources, it is worth the wait to save 80 dollars for a back order.
Posted on Sep 13, 2008
Anonymous
  • 706 Answers
SOURCE: HE5 Dryer not working
Hello dram65,
Check the door interlock switch, if that's malfunctioning or not sensing the door is closed.. it will disable the drying function,
Regards,
Rick
Posted on Dec 13, 2008
The dryer was drying, and suddenly stopped and control panel says call technician. Then says door open, won`t start after unplugging to reset it. The inside light stopped working at that time.
It may have overheated. Wait a couple of hours and try again. If it still doesn't work you will need an engineer to diagnose the problem. As it went out during a cycle it could be high limit thermostat or high limit cut out. Both are available on eBay and Amazon. Those parts fail if the dryer gets too hot caused by bad airflow, clogged filters, exhaust pipe or stuck vent slats outside.
Mar 16, 2016 | Frigidaire Fasg7073Lw 7.0 Cu Ft Steam Gas...
The drum light is out in a GLER104FSS
first, unplug machine. open the dryer door, Remove light protector cap. (pry with flat screwdriver), unscrew bulb and replace a new one
tadamm!! :-)
Mar 30, 2014 | Frigidaire GLER104FSS Gallery Series 27...
Dryer will not operate
We are sorry to hear of the problem with your Whirlpool appliance. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at [email protected] with your name, phone number, address and the model and serial number for your dryer.
Apr 04, 2017 | Whirlpool GEW9250P Electric Dryer
Dryer won't start
First, with the door opened, push and release the door switch. Does the light go on and off?
Dec 07, 2012 | GE GTDL200EMWW 27" Front-Load Electric...
GE dryer heavy duty 7 cycle, just finished drying a load of clothes, put wet ones in and closed the door turned to the cycle i wanted turned the start switch and nothing.... but a light hum...
Check to see if you can spin the drum fairly easy. Also, try to leave the door open, hold the door switch in, and then start the dryer and give the drum a spin to see if it starts.
Sep 27, 2011 | Dryers
High efficency dryer won't spin-Frigidaire
Try this. Set the timer. Open the door, press and hold the light switch. Rotate the drum by hand then while still holding the light switch turn on the dryer. If it starts then clos the door while removing your finger quickly. If this problem persists it could be the starter on your motor.
Mar 22, 2009 | Frigidaire FEQ332E Electric Dryer
I have a Kenmore Dryer model # 86581100. The dryer sounds like it is running rough and it continously runs even when the door is open. The night before when let it running when we went to bed and we could...
You have at least 3 problems, with your dryer; door switch, start switch and drum support. To to retire it for a replacement. Hope this helps!
Jan 28, 2009 | Dryers
Kenmore HE5 Electric Dryer Logo
651 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
Ned Halaweh
Ned Halaweh
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
