Question about Garment Steamers & Presses
The steamer does not produce steam anymore. Barely any steam is made, it mainly spits out hot water.
We used this (Conair Extreme Steam Fabric Steamer with Dual Heat) to iron shirts and clean curtains as suggested in the guide. After not using it for about a year, we are getting this problem. I have opened it up to see and there are no burnt wires and water does not leak inside. I can also see that the pump functions fine and everything seems to run smoothly.
Posted by Arthur Alves Araujo... on
3 Related Answers
Manni F. Bear
  • 15 Answers
SOURCE: Conair Lysol hand held steame
It could be broken but it could also be jammed or clogged by some dirt or water. My first answer would be to get a new one. but if you dont want to throw it away you should take it to a recyling store.i know that is getting rid of it but it is not exactly because you still remember it.
Posted on May 25, 2013
Wylie Johnson
  • 827 Answers
SOURCE: when has my iron stopped steaming and heating up?
depends on how old it is, try to rinse it with a water and vinegar solution, this might help
Posted on Apr 09, 2015
claudeinmo
Claude Kayser
  • 9098 Answers
SOURCE: My Mr Steam is 3 years old. When I turn the unit on, after heating up the unit spits out boiling hot water from the steam head! Help!
Customer support of Mr Steam
Posted on Sep 28, 2015
Shark Super Steamer
The steam generator is defective.
Aug 28, 2016 | Euro-Pro Shark Super Steamer
My steamer is no longer producing steam, how do I fix?
To troubleshoot something like this.
1. make sure it's plugged and the outlet is working.
2. Is it getting hot? If not, either the heating element is burned out or not getting power.
3. If it is getting hot check the steam ports for calcium build up (run straight vinegar through it)
Jul 14, 2014 | Garment Steamers & Presses
Doesn't steam
the hoses sometime kink when hot then get hard in the kink part once cooled down.. you may need to fin the area and warm it up to let the steam pass..
Dec 13, 2013 | Haan Complete Multipurpose Steamer MS-30R
May 25, 2013 | Garment Steamers & Presses
Garment Steamers & Presses Logo
1,307 people viewed this question
Top Garment Steamers & Presses Experts
Tom Chichester
Bill Boyd
ray gallant
Are you a Garment Steamer and Press Expert? Answer questions, earn points and help others
