Question about Hoover Floormate H3000 Upright Wet/Dry Vacuum
When removing the brushes to clean them the entire blue part underneath, I think it is the detergent distributor part also came out. I can't figure out how to get it back in. I don't know if something broke or if I am just not doing it correctly. Does anyone know how to replace that part?
SOURCE: hoover floormate
It seems to be a common problem with this series of floormate... some home quickfixes (a hassle, i kno) but put downward pressure while using the solution.... Check your warranty that came with it, and how long you purchased the floormate... Alot of vaccuums come with 30-90 warranties, I'd recommend having it checked out. That, or if u bought it recent enough,take it back... like i said, these models are unfortunately known to have this problem... Some people have ones that operate normally, but alot do not. >.<
Posted on Jan 09, 2008
SOURCE: Repack the Hoover Floormate
Did you ever get the handle off? I'm having the same problem.
Posted on Jul 12, 2008
SOURCE: Hoover FloorMATE 3000 won't dispense cleaning solution.
I had the same problem with my Hoover Floormate H3000 and found the solution elsewhere on this website. Try doing a search for Hoover Floormate H3000. The posted solution is basically as follows:
Remove the liquid dispenser tank and set it aside. Look into the cavity of the machine where the tank attaches and find the plastic "plunger" piece (the one on my machine is a blue/grey color) that is surrounded by a black rubber circle. Put a small drop of hot glue on the tip of this plastic "plunger" piece and let it harden. Replace the liquid dispenser tank and try the machine again. My machine dispensed liquid properly after this fix-it.
I really appreciate the poster who provided this simple solution!
Posted on Aug 29, 2008
SOURCE: Hoover Floormate brushes won't turn
With the drive assembly removed it is a black rectangle with a black piece extending down and to the right. There is a metalic fitting that engages the brushes. With nothing attached turn the motor on with the switch. If it doesn;t turn either the switch is bad or the motor is burned out. If you have a voltmeter check the ouyput side of the switch. If voltage is there check the motor plug. If good there the motor is bad. Hope this helps. Yes, the motor does get voltage when the switch is on. You can find parts by entering Hoover FloorMate H3000 parts into Google.
Kirk Thompson
San Juan, PR
Posted on Oct 29, 2008
SOURCE: Hoover Floormate H3000-050 power head/taking apart
I didn't find this as difficlut as red devil 6, however, having 2 people helps. Remove the brush assembly using the 2 brush release buttons. Remove the front nozzel by sliding the 2 nozzel release clips away from the unit. Do NOT remove any screws from the underside of the floor mate base.
Before you begin....on the new wheel assembly, locate the "spring loaded lever" that is attached by the 2 brass screws. Notice that it can be pushed to the side and it locks in place. If pushed again it releases. This is important when you go to make sure the wet/dry pick up indicator is working near the last step of the process.
The top grey cover on the base of the unit lifts off accessing the hubs that hold the handle to the base.
To remove the top grey cover, there are 6 clips that you have to move to one side or the other with a narrow flat blade screw driver. All 6 of these clips are accessed from the underside of the base unit. Work gently...red devil 6 was correct, you can break things easily.
GENTLY pry up the top grey cover exposing the 2 black hubs holding the handle to the base. Remove the 4 screws holding the hubs to the base. I found it easier to have the handle in the down position to remove the cover. I found it easier to have the handle up for 2 screws and down for the other 2 screws.
This is where 2 people come in handy. One person (me) holds the handle and base apart while the other person (my wife) installs the wheel assemlby. It is a little tricky to get in place. My wife found it easiest to install the nubs first (yes nubs, like a little axel that holds the wheel assembly to the base) at the back of the wheel assembly, then slip the pin at the front of the wheel assembly into its position (where the old one came from).
Reset handle and hubs into the base and tighten 4 screws.
Before you go any further, make sure your dry/wet pickup indicator works.....The INDICATOR is the thing that has two red spots on it and tells you if you are on wet or dry pickup. GENTLY TRY to work the wet dry pedal with you HAND to see if the indicator swithces between wet and dry easily. If you are not GENTAl and you force it, you WILL BREAK it. If it does EAISLY go back and forth between wet and dry you have to reset the indicator. Push the indicator stem (the stem that sticks down into the base) up through the base and push the spring loaded lever (see before you begin above) assembly on the wheel assembly to the side. Reinstall the indicator stem and make sure the little spring end is positioned over top of the plastic stub. Recheck GENTLY the function of the wet/dry pickup foot pedal, but use your HAND.
Finally, reinstall top grey cover. It's a little tricky but we found it helpful to have the handle in the down position. Make sure it snaps back into place.
You did it!.
This took my wife and I about 45 minutes to 1 hour....but at least half of the time was spent going slow to ensure I didn't break anything else.
Good luck.
Posted on Apr 06, 2009
