On the display board it only comes up as 'dist', most treadmills ive used have kmh or mph infront to indicate the unit of distance. bought second hand so I don't have the manual and cant find the answer online!
SOURCE: treadmill kph to mph
No need to take console apart, power up the treadmill, take the safety key out then hold down the start button and the incline down button at the same time then insert the safety key. You'll now be able to toggle between KPH and MPH by using start button
SOURCE: How do I reset a lifefitness Treadmill 9500HR from
Switchthe power off without unplugging the machine. Do not take the safety key out ofits place.
Inspectthe bottom of your console. The calibration switch is in a small hole. Insertthe eraser end of a pencil into the hole and softly push the button. You willsee CL11 on your console after you push this button.
Usethe Speed + or - key to select MPH or KPH. Push the Power key to save yourselection.Sincerely.E.CUADRAMANAGUA, NICARAGUA C.A.
SOURCE: lost manual for roger black silver treadmill
see the video and proceed according., God bless you
It is simple to change your treadmill so it reads MPH.
Treadmills are an easy and relatively inexpensive way of maintaining physical fitness. Most modern treadmills have a readout on their console that will track your speed over time in kilometers per hour or miles per hour. If your treadmill came with the wrong setting, it is possible to toggle between these two settings.
Instructions
Things You'll Need
