B
Bertha Allen Posted on Dec 12, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a PIXMA3122 printer and want to print address labels on it. What type of labels do I need to use?
Danny Kuhlmann
Level 3:
  • Canon Master 1,443 Answers
  • Posted on Dec 12, 2015
Danny Kuhlmann
Canon Master
Level 3:
Answers
1443
Questions
Helped
262061
Points
4794
Go to avery.com and get the labels and software that you need
Labels Custom Labels Full Sheet Labels Avery
Pls rate my answer, thk you.
Need to know about address labels?
You should be able to use any address labels. The set up will be in your print options menu asking for the size and type of label.
Can you print address on envleope
Yes you can print an address on an envelope. Do you have Microsoft Office? If so, click on new office document and click the tab that says Letters & faxes (for versions before 2007) and choose the label wizard. When the window opens, click the tab that says envelope instead of label and follow the prompts to type in the information you want to print on yoru envelope.
If you have Office 2007 - or newer, click on new office document and then choose blank document. Click on the tab at the top that says mailings and then choose envelope and type in the information you want to print on your envelope. Then click on file, and print. You will need to load your envelopes in the printers tray and put them in the correct direction according to the settings your machine requires. You might need to waste a few envleopes until you get it right.
When adding the Dymo labelwriter 450 turbo to Windows 7 machines, the installation completes fine. When attempting to print, an error shows up in the device manager that says Access Denied for the print...
i HAVE LABEL WRITER 450 TWIN TURBO AND I CAN NOT PRINT RETURN ADDRESS LABELS. i HAVE UNINSTALLED AND INSTALLED AGAIN THAT DOESN'T WORK THE RETURN ADDRESS LABEL IS THERE IT WON'T LET ME TYPE ANYTHING IN THE SPACE PROVIDED IT WAS WORKING FINE THEN THE NEXT DAY IT WAS NOT
THANK YOU
1helpful
How do i find the IP address on a Zebra Z4MPlus?
If you can not see it in the LCD menu on the front panel, you can find it by printing the IP info on a label. There is a reset button near the Ethernet jack that will let you reset the print server settings or allow you to print a config label. Load up some media, power the printer on. Once the printer is fully booted, use a paper clip or the like to press the button once. A label will print that details the IP settings. Once you have the IP settings, you can log into the printers web interface by typing the IP address in your browsers URL bar. Do get a copy of the manual.
1helpful
I have an I Mac 10.58. I have typed into an Address Book 62 addresses that are stored on an Address on an a group labeled "Xmas Group." Separately I have typed into "labels" the #8167. What is the...
Have the group selected and then select print from the file menu.
Make sure that the arrowhead next to you printer name is pointing upwards.
Under the from to page selector it should say Address Book.
Below that is should say Mailing Labels
On the next line down select the 'Layout" tab.
Check that you have selected US letter then select 8167.
Then hit print.
That's all there is to it. I just tried and it printed 4 columns of 20.
2helpful
2answers
Smart LabelPrinter Seiko 440
The code between the labels indicates either you are using labels designed for another model or that it is thinking it has a shippinhg label opr some lareger type installed. IT is more likely to be the first option, you are usinjg the wrong coded labels
Please rate my help++++Thanks for using FIXYA
1helpful
2answers
Printing labels setup on the PXMA MX860
You don't need to do anything to set the printer up except to tell it you have heavier stock than normal.
Your answer lies in the program you are using to print labels. Please tell me which program you are using and what other office type programs you have on the computer and I will try to give you a viable solution.
Chris
Printing addresses on labels
did set the parameters in the system before printing labels you can make a new printer control in printers section to only be label printed with the same printer you use
when you goto print click on the new print control that you have set for labels this way your software wont get the big confusion of paper or labels
Just changed labels to 99010 and can no longer print
Did you change the label type in the printing preferences?
1helpful
4answers
Label Printing
I had the same issue when using Avery labels, here's what resolved it for me.
Go to Control Panel, Printers, go to the active default, right mouse click, click Printing Prefrences..., change the drop down "Type is:" to 'Other Photo Paper" and apply.
You should then be good to go!
old marine
old marine
ZJ Limited
ZJ Limited
