Question about Connex Radio Communications
Just bought a connex coyote hunter.the antenna i have is for cb i know that for 10 meter radios you have to have a antenna thats tuned.on cb band shouldn't i be able to hear On cb band? With cb ant?
Posted by Jeff white on
normis101
    New Friend:
  • 69 Answers
To recieve signals on 10 or 11 metres with the same antenna is usually without problem, it's when you try transmitting that the correct antenna length is vital. If it's not correct, you can , at the least, get very little power being radiated, and at worst, the power going back into the transmitter and cooking it. If you have to ask these questions, you should not be on the 10 m amateur band anyway.
Posted on Dec 24, 2015
Andrew Taylor
    Top Expert:
  • Connex Master
  • 33,346 Answers
The antennae has to be tuned for the radio not for the band you are listening to. If is a 10 metre band, so you need a 10 metre antennae which enables you to listen to both bands, but looking at the jpg of the radio it gives bands A, B, C, and D, nothing about CB radio itself, but the option of AM and FM radio.. Using the wrong antennae could damage it.
you could get some help here
http://www.cbradiotalk.com/viewtopic.php?f=9&t=29531
specs here
Picture and Specifications of the Connex Connex Hunter Mobile Export Radio
Posted on Dec 12, 2015
2 Related Answers
Communicomm
David Eisenberg
  • 90 Answers
SOURCE: connex coyote hunter will not transmitt
It's possible (but not very likely) that the final amplifier blew out after you lost the tip of the FireStik antenna.
Posted on Jul 20, 2008
anymhz
AnyMHz.com
  • 500 Answers
SOURCE: how to convert a connex
That needs to be done by someone that knows how, theres soldering involved. most cb shops will do it for $free-$10.00... Don't pay any more than that.. there are no parts nor is it hard so they shouldn't charge much.
Posted on Mar 01, 2011
Can I tune my antenna using the meter on my radio?
yes,but you want to make sure your antenna is tuneable.If your SWR is to high or to low you want to be able to adjust the antenna to bring the match up or down.Anything under a 1.9:1 is ok but the lower the better
Jul 15, 2014 | Connex 3300 240-Channels Base CB Radio
So im gonna have to get my own SWR meter to tune my antennas right?
not really.Many radios come with one built into the meter on the radio. For those with none you will need an external SWR meter. I would recomend a trucker 2000.
May 15, 2014 | Connex 4600 Base CB Radio
Why does the red light for antenna stay on
This means that your swr is high. you can damage the radio using it in this condition, check antenna and coax for damage or misinstallation
Feb 27, 2014 | Connex Cx-3600Hp 3600Hp 10 Meter 100 Watt...
Fix my connex 3400 hb sideband button
Hi there, if you are talking about the Connex CX 3400 HP there is no sideband or SSB on this radio. It is only AM and FM 10 meter Ham radio. Many people do modify these radios to include the 11 meter frequencies which is the CB band. Maybe knowing the actual bands and their frequencies will help some too this radio does have 6 different bands ranging from (Band A. 28.015 thru 28.455) (Band B. 28.145 thru 28.585) (Band C. 28.115 thru 28.555) (Band D. 28.085 thru 28.525) (Band E. 28.055 thru 28.495) (Band F. 28.025 thru 28.465.) I hope this will help you. Bob
May 13, 2012 | Connex CX-3400hp AM/FM 10 Meter Amateur...
How to convert a connex 3400 hp to cb radio band from 10 meter band.
Feb 12, 2011 | Connex 3300 240-Channels Base CB Radio
Can"t transmit
I believe that if the radio is not tuned to the antennae it can take out the transmit crystals and the radio will be inoperative. You will have to take it to a shop that works on CB Radios to have it checked.
Jul 31, 2009 | Connex CX-4300HP CB Radio
Connex coyote hunter will not transmitt
Jul 12, 2008 | Connex Radio Communications
Frequencies
i have a 4600 connex and if i turn the mic gain all the way up i get alot of modulation.can someone tell me how to fix that?
Feb 01, 2008 | Connex 4600 Base CB Radio
10 meter portable
There is no factory made 10 meter CB Radio made for US use. CB Radios use 11 meters, and the FCC doesn't allow the combination of 10 and 11 meter radios combines. Although, many people modify 10 meter radios to work on the 11 meter ( CB ) band, it's not legal. Good Luck
Ed
NC Electronic
Mills, Wyoming
Dec 15, 2007 | Magnum 257 CB Radio
Matching Antenna, or ??????
If the antenna is tunable, you definitely need to start out by having the swr set properly on the antenna. Also, make sure the plastic ferrel, (the small round white piece) is between the top of the antenna bracked and the antenna itself. It is there to make sure the antenna does not ground out to the vehicle. If the antenna is grounding out, it will be like no antenna at all. I have also had a few customers that have had broken coaxes straight out of the factory package on cheaper antenna setups.
Dean
Rollin CBs
Feb 08, 2007 | Uniden Bearcat Pro PC78LTW 40-Channels...
Radio Communications Logo
265 people viewed this question
Top Connex Radio Communications Experts
Tony Raia
Marvin
Marvin
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
