Question about Fisher and Paykel GWL11 Top Load Washer
Why does it leak, even when machine is not running?
Checked all hoses not coming from there.
Posted by Patricia James on
Claude Kayser
    Top Expert:
  • Fisher and P... Master
  • 9,098 Answers
Small leak/drip with Fisher & Paykel GWL11 Washer (with ...
ths.gardenweb.com > Home Forums > Laundry Room
May 6, 2008 - Got a small drip/leak with my GWL11 washer..... The washer is ...Small leak/drip with Fisher & Paykel GWL11 Washer (with pictures) ..... New project for a new year: Light a fire under plans for an outdoor oven and claim the best pizza in town ... Speed Queen Front Load AFN50 Washer Review - Long Post.
Fisher and Paykel GWL11 Top Loading Washer
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... I have a Fisher Paykel GWL11 that I purchased new and have loved until this problem started. ... The machine fills with a small amount of water to saturate the clothes ...... Fault 36 is related to water leaking, but is *not* the kind of leaking from ...
Fisher and Paykel GWL11 Top Load Washer - faqqq
www.faqqq.com/.../fisher-paykel-gwl11-washer-leaking-and-squealing-fish...
Question Product: Fisher and Paykel GWL11 Top Load Washer Question Details:Fisher Paykel ... Small leak/drip with Fisher & Paykel GWL11 Washer (with .
Posted on Dec 12, 2015
Hoover 960 elite series 2 leaking but not from outlet hose
Hi just read your posting.Most of the time when this model of machine leaks it is the drain pump.Have you checked the drain pump?Is the machine noisy on spin?When the machine is running, look underneath the machine to see where the leak is coming from.Please reply with additional information and i am sure i can help you.Looking forward to your reply.
May 18, 2011 | Washing Machines
Water leaking from bottom of machine however I cannot find a leak when inspecting from the bottom with the machine tilted back. Fisher & Paykel model GWL11. I have not been able to determine when (...
Hi just read your posting.Now have you checked for the leak where the drain hose comes out of the case of the machine? It is located at the back top left of the machine.Have you checked the inlet hoses at the tap end and the machine end?Rub the inlet hoses with your hand from the tap to the machine on both hoses to feel if there is any water on them.Check the nozzle under the lid where the water comes into the machine to see if it is not loose or broken.Please reply and let me know how you got on and If you need further help.Looking forward to your reply.
Sep 04, 2010 | Fisher and Paykel GWL11 Top Load Washer
Water leaking from enderneath, checked all hoses
could be coming from the drain pump seal,,,or main tub seal,,,,outter tub could have a crack in it,,,,i would remove the outter shell and run it to see where it;s coming from!
Apr 26, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Water leak
i went to the parts store asked about it and they told me what to do . I didn't even buy a part from them.
Jan 13, 2010 | GE Washing Machines
Dodge dakota vacume problem
You need a diagnostic box to tell you what the problem is.......if it is a evap leak,it could be anywhere,the hoses,the gas tank seal,a cracked hose.If you can go to a dealer they might have a smoke machine, they watch to see where white smoke is escaping from.Which is impossible to tell other wise. Could even have over filled the gas tank,that would give you an engine light......
Jan 17, 2009 | 1998 Dodge Dakota
Washer top
The following link should give you the steps necessary to remove the exterior washer casing to inspect the interior:
http://www.fixya.com/support/r397092-replacing_water_pump
The instructions are for replacing the washer pump, but the steps to gain access to the interior are the same. If the leak is coming from the FRONT of the washer, check the pump and drain hoses for loose connections. If the pump is leaking, it is not repairable (sealed unit) and must be replaced. If the leak is coming from UNDER THE WASH TUB, this is a symptm of a leaking tub seal, or cracked tub. This requires removal of the wash basket to replace either part. If the leak is coming from the SIDE of the wash tub after it starts to fill, check the air dome hose to ensure it is still attached and not leaking. This is a small air hose that connects to the side of the wash tub and runs to your pressure switch. It sometimes becomes loose or disconnected and leaks. If the leak is coming from the BACK of the washer, check the fill hoses and water inlet valve hoses. I hope you find this information helpful. If you need further assistance, please let me know.
Oct 19, 2008 | Kenmore 15864/15862 Top Load Washer
Where is the filter
filter should be checked regularly and is a pain to do on hotpoint. however, blocked filter would not cause leak.
remove small panel at bottom back.
you will see a large diameter hose running from tub to pump.
undo this hose at the tub end and you will find filter inside hose.
carefull, water will come out
Sep 17, 2008 | Washing Machines
Kenmore washer leak
With the machine unplugged and EMPTY disconnect the water and waster water connection from the wall and tip it forward you should then be able to access the pump.  Check the hoses running to the pump. (usually white plastic with 2 large and 1 small hose running to it.. you can also just move it away from the wall with it completely connected and run it thru a cycle to see where it is leaking from.
May 26, 2008 | Kenmore 24032\24036 Top Load Washer
Water output hose
normally, they are just clamped to the outlet of the water pump. but be aware that you still need to raise the part of the hose as they come out of the unit in order for the machine to work. if you leave the hose just lying on the ground,as the machine fills up, water would be leaking down the drain even though water pump is not running. pressure switch will not be triggered and machine will not run.
Feb 18, 2008 | Whirlpool LBR5432PQ Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
794 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Michael Thomas
Michael Thomas
peter gittos
peter gittos
Marvin
Marvin
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
