Question about Westinghouse Televison & Video
Why is there no audio output from Bose Sound Touch speaker?
Posted by SuL Rus on
5 Related Answers
Anonymous
  • 51 Answers
SOURCE: Brookstone Wireless Outdoor Speaker with Bose 123 System Problem
AUX usually refers to an INPUT, such as a CD player, etc. No signal comes out of a standard AUX jack, unless it specifically says "Aux speaker output". Instead, look for another speaker output jack, such as remote speaker, B speakers, etc. You may only have one set of speaker output jacks, in which case you would need to connect your wireless speaker to the speaker output jacks along with your main speakers, or buy a little speaker selector switch box to switch between main and wireless speakers. There's usually no harm in connecting more than one speaker set to the same outputs, though it is technically not recommended. In the real world, just don't crank it too loud and you'll be fine. The wireless speaker MIGHT run off of a standard line output also, if the wireless speaker has its own power amplifier.
Posted on Dec 27, 2008
Anonymous
SOURCE: CANT CONNECT MY BOSE COMPANION 3 SPEAKER TO MY 42LG50 LCD TV
I have just brought the bose companion 3 speakers and i connected it to the headphone socket in my tv and it worked.
Hope this helps
Posted on Apr 15, 2009
Anonymous
SOURCE: No sound at laptop speaker but audio output is ok
I have lenovo notepad 3000n100 with winXP sp2.
I downloaded realtek audio from ibm site and installed.
Now sound is coming at my output port but the in-built laptop speaker is not giving any sound output.
The hardware is ok as the sound was coming at in-built speaker before formatting. The previous audio driver set up file i have lost.
Plz help.
Posted on May 20, 2009
Anonymous
  • 103 Answers
SOURCE: Bose Companion 3 and Realtek HD Audio Card - No sound
Hi: I'm sure you checked the volume control of the Bose controller. Check where you plugged it in to the back of your computer. Mine has a veriable outpup and a fixed output. I hope this helps, Jeff
Posted on May 31, 2009
Anonymous
SOURCE: when i put the ipod touch in the bose docking
I am having the same issue my touch, did you figure out what it was?
Posted on Aug 26, 2009
Tthe sound wont play on my new vizio 3d tv
  1. Check your connection from the TV Audio output to the Bose Input, and make sure the TV is not muted.
  2. In the TV's Sound/Audio menu, configure the TV to output the sound to External Speakers, not the internal speakers.
  3. Make sure the Bose system is powered on, and not muted.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Mar 12, 2011 | Bose Lifestyle 48 System
How can I hook up my Bose cinemate on my Philips HD tv when no there is no Audio out and I want to use it for my dvd player, cable box, and video systems?
You don't need to send audio TO a TV. I's a TV, not a source of anything. Many of us use monitors (no TV speakers). The Bose speakers are presumably superior to the TV speakers so whatever the TV is watching (cable/sat/dvd) shuld have its own audio.
Page 11.
If your TV does not have any audio output jacks, you can connect the CineMate™ speaker
system to the audio output jacks of another source, such as a DVD player or cable/satellite
box. However, you will hear sound only from the connected source through your CineMate
speakers.
http://www.retrevo.com/support/Bose-Cinemate-Speaker-Systems-manual/id/526dj591/t/2/
Dec 25, 2010 | Bose Cinemate Digital Home Theater System...
BOSE SPEAKERS INOP,RCA CABLES PLUGGED INTO DIGITAL OUTPUT OF MY HP PAVILION. TRIED DIFFERENT CABLES.DONT KNOW IF IT DRIVER RELATED.REALTECK DIGITAL OUTPUT SHOWS PLAYING MUSIC BUT NO SOUND JUST HUM
you might have to uninstall then reinstall either the driver or the sound devices
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers or right click select properties to either troubleshoot,uninstall,rollback driver
hope this helps
Oct 25, 2010 | Bose Companion 2 Series II Multimedia...
Good morning. I want to get an idea on how to connect my Panasonic lcd TCL32X1X to my Bose Sound System. What I want is to hear tv programs thru the Bose speakers.
TV's are video OUTPUT devices, not sound INPUT devices.
Get the TV-related audio into the Bose directly from the digital audio output of the same source from which the TV is getting the video. You can also run a mid-fi RCA analog stereo feed to the TV (if it has speakers) so you can watch and listen to stuff without the Bose turned on.
Jun 28, 2010 | Audio Players & Recorders
BOSE Companion 5 speakers connected to an Apple but no sound.
if you have a bose disk then you will need to run the install disk firsthope this helps if it does please rate this answer
May 12, 2010 | Computers & Internet
Do you have the USB cable plugged into your Mac?
Mar 20, 2010 | Computers & Internet
Bose surrond sound not working...
Your TV may have a setting to make its Audio Output Variable or Fixed. That is, as you turn the TV's volume down or up it will either vary the output (as it seems to be doing in your case) or keep it Fixed so external electronics can still use it when the TV's volume is down or off. Some TV's do it another way - they have a selection to turn the TV's speakers OFF.
Feb 03, 2010 | Bose Cinemate Digital Home Theater System...
Connect Bose System to Panansonic TV
in the tv setup menu there should be an item that will allow you to change the volume from variable to fixed on the output of the tv
Dec 07, 2009 | Panasonic Audio Players & Recorders
LG 47 External Audio Control
This is the only way a bose works
May 01, 2009 | LG 47 in. Flat-Panel LCD HDTV
Cinemate won't play through LG 50 Plasma 750p
use the audio input of your cinemate to connect into tv audio out using rca cable. please check your tv if it has jack for audio out.
Mar 28, 2009 | Bose Cinemate Digital Home Theater System...
Televison & Video Logo
236 people viewed this question
Top Westinghouse Televison & Video Experts
CoppellTVRepair.com
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
