batteries are available from e-bay
one dead battery will not affect any others
all hand sets make calls and receive calls through the base unit that is connected to the landline
base unit is connected to the landline and operates any hand set that is picked up
make sure all handsets have the end call button pressed as one not pressed after use may keep a line open
call your provider to check the land line to your premises
borrow a neighbours phone and plug it into the socket and see it you get a line on their phone
Try reset your wireless phones, Turn
off the phone, remove the AC adapter, press and hold the page/call
button that is on the phone and plug back your Ac adapter, this process
will help reset the phone and help fix all abnormalities.
You may have a problem with your battery. Usually the rechargeable battery goes bad on those units. Swap the battery from the working handset to one of the non working ones.
If you have tried it in known working telephone jacks, then your phone is dead. Probable voltage spike or lightning damage. If it's just the handset that is not working, but you can use the base to call out and receive calls, then your handset ids bad, or the base isn't charging the handset. Best solution if handset is bad is to find the receipt and exchange it.
It is likely your phone has a mouthpiece or ear piece problem that is why the reciver can't hear you.So your need to take the phone to the nearest repair office for it to be changed.
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
