Everything acts as normal till you press start and then the light switches to "wash" and nothing proceeds to happen, at all. Tried clearing out the filter and removed a coin, but no improvement.
SOURCE: No power to washing machine but fuse is ok...
could be 2 things 1)try closing the door and banging the machine on the front next to where your door catch goes into the washer if it starts could have a lose wire or be faulty 2)if no1 doesnt work than it will be your mains filter which if blown power doesnt get to your machine if the machine is brand new and has manufacturers warranty then these are covered through the warranty and any tampering will void your warranty though should be covered for no less than a year
SOURCE: HOTPOINT aquarious extra
whare the option buttons are if you number them 1 to 5 from top to bottom if led 2 and 4 are flaching this is a time out draining and you will need to check your waste hose for twists traps and kinks also check Filter if there is a user servicable one on the applionce and check plumbing. This is a comman fault and if you get hotpoint out to it even if it is only a day old they will charge for the call out as it is classed as user error or faulty instalation this works on all WF,WD & WT modles with 5 option buttons on the left habnd side the applionces with digital displays will show F-05 insted but it all means the same
SOURCE: washing machine tripping everything in the house
Washing machines take out ring main fuses if there are faults in the machine:
washers heater unit
motor
or suppressor.
Also water may have breached a seal somewhere and cause a short inside the electrical compartments.
To fix a fusing washing machine you have to use a diagnostic electrical meter that puts high voltage across the appliance - Not something I can offer more info on. So whatever has happened (and in the interest of safety) you would probably want a qualified proffessional to take a look or as a last resort a hotpoint engineer!
SOURCE: Washing machine Prewash light flashing.
hi on the model before this one the wma series the flashy pre wash light is a faulty water inlet valve these mashines are allmost identical inside so check that,first check that you have the hot/cold pipes on the right way around hope this helps
SOURCE: hotpoint aquarius wf101 washing machine wont start
fit new door interlock switch not too expesive parts about £15
its a WF541 btw
