For the past several years the evaporator would frost up about every 6 months and a forced defrost would get it working again. This time the forced defrost doesn't seem to be working correctly.
SOURCE: fan in freezer - evaporator fan?
HI. thanks for the question. yes the fan in the freezer must be replaced.and also the drain tube in the freezer, is clogged. cut power to the fridge. remove back panel . replace the fan motor . also clean ice build up. clean drain tube, from freezer to the drain tray, at the back, near the compressor. thanks the appliance doc. please rate my answer. thanks
SOURCE: Food and water freezes but ice cream is soft
Check the door gasket seal.
Open the door for a few seconds and then close.
Immediately open the door again, and, if sealing properly, it should take more pulling force to open the door.
SOURCE: refrigerator evaporator fan won't run but compressor working
is the evaporator coil frozzen you may have a defrost problem
SOURCE: freezer frosts up and stops cooling after approximately 2 weeks
With your new timer in hand look and find a slotted screw driver head that you can turn. That is to manually advance the timer. Now put the new one in and advance it to engage the compressor and fan. Might be in the middle of defrost mode. Your unit goes through 3 defrost modes in a 24 hour period. And each mode last for 20 minutes. Once you do this I could help further if that was the case. Okay ken
SOURCE: Compressor & Evap. Fan both work for 12 hours then evap stops
I believe that because defrost is done by the mother control board this is why this is happening the part of the board that controls defrost is malfunctioning and the only way to resolve the problem is to replace the mother board part number WR55X10656 You can find the replacement board at these places below. Sea Breeze
http://appliancepartsse.blogspot.com/
Testimonial: "You were right, thanks for your help. The control board was bad. That is what I suspected, but I wanted a second opinion."
