Kodak easyshare mx1063 10.3mp 3x optical/5x digital zoom hd camera si Logo
D
Debbie Pratscher Posted on Dec 11, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Camera has not been used in a few years. Is plugged in to charged but green light is not on. Does this mean it needs a new battery? Batteries that came with camera are rechargeable.
richie46
Level 3:
Top Expert:
  • Kodak Master 12,962 Answers
  • Posted on Dec 11, 2015
richie46
Kodak Master
Level 3:
Top Expert:
Answers
12962
Questions
Helped
2945131
Points
58151
Yep - have gone to battery heaven and will not take a charge.
NIKON MH26 BATTERY CHARGER BLINKING GREEN LIGHTS
A blinking green light means the charger is charging the battery. A steady green light (same LED) means that charging is complete. If the light never stops blinking and we assume that your charger is working correctly, you may have a defective battery. Rechargeable batteries do not last forever. After a few years, there ability to take and hold a charge declines. It may be time to buy a new battery.
1helpful
Orange light flashes on when turn on Olympus c-50 zoom camera and orange and green lights in upper left corner blink when try to take pictures. Won't take any pictures
The flashing Orange light means the charge is flashing.
The flashing Green light means the focus and exposure are not correct.
Have you recently replaced the batteries? Or are you using rechargeable batteries? Lack of enough "Juice" could allow for the flash to not charge up (Orange) therefore not allowing the camera to get the correct exposure (Green). I would try new fresh batteries or a new battery pack. If that doesn't fix the issue it must be a bad circuitry in the body that is shorting not letting the flash charge.
Regards,
Jacob
My camera will not come on.
hmmm...if the lens in the front is stuck; take the batteries out, charge em (rechargable batteries), put em back in, press the power button once. the lens should come back in only. leave it for a while. hmm...if the green power does that then u need to charge ur batteries again for a really long time. it means the camera will not use the juiceless batteries.
4helpful
When charging battery green light flashes then red 3 times
KODAK Easyhare digital camera light status
1. Blinking green light(or blinking blue or white light in some models) - Means camera is performing a power up procedure. Note: Wait a few moments to see if the camera displays a solid green (or blue or white) light or a blinking red light.
2. Solid green light(or blinking blue or white light in some models) - Means Camera has sufficient power
3. Blinking red light - Means camera batteries are weak or need replacement; If battery are new and still red light camera needed to be repaired
For futher assistance contact Kodak support line 1 800 235 6325 (23KODAK)
4helpful
2answers
My camera cannot turn on or off is only 3 months old tried what might be the problem? i tried to charge the battery nothing happened i tried to take the battery out and back on still it did not work. i...
1. Remove the batteries from the camera and the memory card
2. Batteries should be Li-Ion Rechargeable Digital Camera Battery KLIC-7001 3. Verify batteries are inserted correctly
4. Place the camera in Auto Mode (Its green camera icon on the dialing mode)
5. Turn on the camera (if it failed try charging the camera)
6. Plug the USB AC adapter into a working power outlet.
7. Connect the USB cable to your camera and to the USB AC adapter.
a. If lights on battery charging light [solid green]
>charge the camera until light turns off or (up to 3hours)
b. If lights on battery charging light [red or flashing red]
>camera batteries are weak; replace with recommended batteries
c. If lights on battery charging light has [NO light]
>Try new set of supported batteries to test the camera one last time
>If already tested with a new set of batteries, set up the camera for repair
8. After all the step still camera will not work contact Kodak support line at 1 800 235 6325 (23KODAK) ** since the camera is less than a year it can be sent for repair in warranty. To receive warranty entitlement, you need to include a photocopy of the receipt or proof of purchase
NOTE: If Kodak repair center finds out customer induce damage, you will pay for the repair cost
3helpful
2answers
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
When I depress the shutter button to take a photo the green light turns to red and will not take a photo. New battery. Help?
Red light indicates battery is out of charged.
What type of battery are you using?
the recommended battery for your camera is the AA Ni-MH batteries
now if your using this batteries Ni-Mh and charged it still id did the same thing., How long you already used this batteries more than 2 years now? If yes it means the battery or the Ni-MH is already defective it means that the chemical contect of the Ni-MH is already crystallized and for you to solve it you need to reconditioned the battery or may be purchased a new battery. Gudluck!
1helpful
Camera will not turn on
It may help to remove the batteries for a few minutes or clean the contacts. Repair of cameras is more expensive than replacement, but it may help to clean and charge the batteries as described below.A friend asked me to clean and charge her new 2000mAh Duracell batteries as described in the next link. Those batteries are still going strong after four months of normal use and have not been recharged.Click this link for other camera tips and complete instructions on cleaning camera and battery electrical contacts. http://www.google.com/base/a/4210404/D13...Also, digital cameras reset to original settings if batteries are removed for one minute. Time varies with function/camera. Check display/setup menu for non-auto functions and date/time. Remove extra memory to eliminate this as a possible problem. Insert fully charged/cleaned batteries and restart camera. The ultimate non-physical repair for software-using devices is reset by removing power ... VCR/DVD players one month.Most NiMH rechargeable batteries lose charge and should be recharged when not used after two weeks, but Duracell and RayOVac new formula 2000mAh NiMH batteries hold charge one year when not used. Also, 2000mAh batteries seem to have a longer life. Did not like these batteries at first, but have 12 over five years old and all are still as good as new. Higher mAh batteries (about one year old) still work well in flashlights, but won't start my camera.CAUTION Do not overcharge! Batteries can be damaged. Use an automatic two or more hour Energizer Compact smart charger with temperature monitor, trickle charge technology, and safety timer ($9.76) at Walmart. Use pre-charged 2000mAh Duracell ($12.97) or RayOVac ($5.97) batteries (both hold charge one year) and a full cycle charge. To preserve battery charge, use the viewfinder.If batteries are removed more than a few hours, the date/time setting and other set-up information will be lost. If the camera is being stored for a long time, the batteries should be removed and stored properly.Carry and dispose of batteries in baggies, blister packs, or other containers to protect ends from short circuit. Batteries explode when short circuited. NiMH batteries are environmentally friendly and may be discarded with trash.The next link is about prolonging the life of lithium-based batteries which last from two to three years, but are very expensive. A Sony series G rechargeable 960mAh lithium-ion battery is $49.88 at Walmart.http://www.batteryuniversity.com/parttwo... ...Camera reports batteries low, but is it low charge or bad electrical contacts? Overcharging can ruin good batteries! The secret to making digital cameras work better is having good electrical contacts between batteries and camera.Digital cameras require lots of power. Bad electrical contacts can cause lots of problems so battery and camera contacts must be cleaned properly. Batteries may be fully charged, but camera will indicate "low" if contacts are not really good. The LCD screen is a low steady load, but when lens extension, optical zoom, focus, and flash charging are added in the capture mode; the load is very heavy. Bad contacts make cameras do strange things like making bad pictures or shutting off with the lens out. NiMH batteries should be recharged when camera reports batteries low. Old batteries can discharge over night, but may provide normal service immediately after being charged. Battery pairs no longer usable in cameras may work well in flashlights. Do not drop batteries or allow voltage below one volt.CAUTION To prevent memory card corruption, keep batteries charged, format in camera, and don't delete or fill card completely. Wait for lights to stop flashing then turn camera off before removing memory. For card readers, double click Safely Remove Hardware. Select, then click Stop and OK.Never touch battery ends or camera electrical contacts. Oil from fingers will contaminate contacts. Use batteries in matched pairs of same brand and rating. Do not mix old and new batteries. New will only do as well as old.Click source link for other camera tips and complete instructions on cleaning camera and battery electrical contacts.
2answers
Battery Charging light doesn't flash and battery doesn't charge
I have the same problem. Worked for 3 years and now the battery charges to green but goes dead immediately. I've changed batteries. Its the camera not the batteries. Works fine plugged in. Obviously the cameras are not charging the batteries. Canon must know but I cannot find a fix and warranty is over. I guess buying the expensive camera of the day isnt always assuring you of quality.
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
