Question about Haier Refrigerators
Why isn't it cooling? - Haier Refrigerators
Posted by Melvin Beard on
aaahandy
    Habit-Forming:
    New Friend:
  • 186 Answers
Do you fell the compressor come on?
Posted on Mar 08, 2016
Ive just bought a hot point ffa74 fridge freezer an it's now been plugged in for around 3/4 hours and the freezer isn't getting cool neither is the fridge, on the control panel there is a green...
The normal cool time for a machine is up to 24 hours, so I wouldn;t worry about anything at the moment, but if the product isn'l cool by the morning I would return it as a defect
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 14, 2012 | Hotpoint Refrigerators
I am in saudiarab i have crown victoria 97 model it is working good but i have problum in air condition system when i run my car its running good no problum but when i start my air condition it is heating...
The air conditioning condenser creates a lot of heat when the a/c is on. The cooling fan is supposed to run the whole time the a/c is on to keep it cool. If the fan isn't on, the radiator will absorb this heat and cause your car to over heat. You should also check your coolant level. So, it sounds to me like your cooling fan isn't working.
Sep 13, 2011 | 1997 Ford Crown Victoria
Freezer is cold, refrigerator isn't
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 26, 2011 | Refrigerators
Maytag MDS2351- came home one day and noticed water coming from where u get the ice and water when i opened the freezer it was not cool and everything i had in there was defrosted and then when i went to...
Your fridge operates like that: a compressor liquefies freon vapours; this creates heat so the hot liquid goes thru a cooling radiator with a fan on it (these 2 elements are at the rear bottom of the fridge) the freon fluid goes to an evaporator, turns to vapour and absorbs heat in the process, cooling the evaporator; a fan blows air over the evaporator and spreads the cooled air all over the fridge; the vapours return to the compressor.
In the rear of the fridge you should make sure that the radiator is clean and the fan working; inside the fridge you should make sure that the evaporator is not covered in ice and/or dirt and its fan is working. If necessary clean both.
If they are clean , the fans work but the evaporator isn't cold then either the freon circuit has sprung a leak and all the fluid has been lost or the compressor isn't working - to find out which just put your hands on the compressor : if it's hot and vibrates the fluid has been lost, if it doesn't vibrates then the compressor isn't working.
The compressor isn't working because either the thermostat or itself have failed. To find out which the compressor will have to be powered directly from the mains: if it starts then the thermostat must be replaced, if it doesn't the compressor will.
To fix the freon circuit or to replace the compressor a certified professional is mandatory, you must call one.
Jul 12, 2011 | Refrigerators
My refrigerator isn't cooling. The freezer is working fine though. Any suggestions?
heatman101
Jul 07, 2011 | Refrigerators
Freezer appears to be working, but not the refrigerator section - at most that will only get to 50 degrees. Manually switching to propane makes no difference.
Sounds like your cooling fan is out. If the freezer is fine and the fridge isn't, then the cooling fan isn't blowing the cold air the the fridge. Or you could have ice obstructing the airflow.
Jul 01, 2011 | Refrigerators
Rudd air conditioner isn't cooling,blowing ,but isn't cooling my house because air is not cold
Hello, first check if the outside unit is running, if it is then check filter to make sure it is clean and that the blower wheel is clean and not dirty. If the unit is clean then most likely you have a low refrigerant charge due to a leak and will need a hvac tech to come out and fix the leak.
Jun 19, 2011 | Ruud UAMB Air Conditioner
Air conditioning wont cool went the car is park
Sounds like your condensor cooling fan isn't working. It cools while driving because air is forced over condensor while driving. Tio prove this, place a box fan in front of the car and turn it to high. Watch it start cooling.
Apr 17, 2011 | 2003 Mitsubishi Outlander
I have an older Whirpool fridge it isn t cooling
does the motor run if not change the thermostat but if it runs the gas level are low in the system
Jun 16, 2009 | Refrigerators
Refrigerators Logo
106 people viewed this question
Top Haier Refrigerators Experts
Vernon Taylor
John Tripp
John Tripp
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
