Music Logo
Anna Trscher Posted on Dec 10, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Roland td4 and my hihat doesnt Work. It works if i plug it into another Set, I exchanged the wire and Reset the computer to factory settings but nothing helped. any other suggestions?
Alex
Level 2:
Champion:
  • Expert 207 Answers
  • Posted on May 10, 2016
Alex
Expert
Level 2:
Champion:
Answers
207
Questions
Helped
57407
Points
299
It sounds like the jack on the unit which you plug the high hat into is defective if it works on the other unit.
3 Related Answers
Starfish Phoenix
  • 73 Answers
  • Posted on Apr 23, 2009
SOURCE: Roland Dp 2 Damper Pedal dont work
I'm 90% sure the pedal is shot ... It could be the switch ... Open the thing up (If your confident) and look to see if a wire has come loose ... If no wires are loose then try another working pedal with the keyboard.
If it still won't damp then there is a problem with your keyboard and I do not suggest opening up one of those ... I used to repair sockets and keys on those for a local boys school and there are full of things that can break if not opened properly,
My suggestion is getting someone in to repair the keyboard if its that ... If its the pedal then either get a new one if you don't want the old one repaired ... Or repair it yourself (pretty easy if its the wiring ... fiddly if its the switch but only attempt if your confident and have the proper tools).
Fred Yearian
  • 5603 Answers
  • Posted on Jul 26, 2009
SOURCE: Can't turn on Roland Fantom G8 keyboard. Tried
Check your power cord. Sometimes they break near one of the plug ends. Use an Ohmmeter to verify continuity.
gd1xinc
GD1x
  • 11 Answers
  • Posted on Feb 07, 2015
SOURCE: Someone help me?
pedal broken, stuck in closed position
2answers
No sound on a Roland model KR-4700. All 4 fuses inside are ok.
Do you have an owner's manual......first thing to try would be a factory reset...sometimes this will un-scramble the operating system and set it back to when it left the factory....contact Roland for an owner's manual if you don't have one....hopefully this helps..if not, then you will have to open it up.....
In my gr 33 the volume is very low. mistakenly i did a factory reset after that the volume is becomes very very low. Any solution for this problem?
There is probably both a global volume and individual program violume as well. One or both may have reset to a lower level and need to be turned up. It's also possible that the general output has a setting for line level or instrument level, which may be software controlled. Take a look through your manual to find these settings and adjust to suit.If all else fails, contact Roland Customer Service at this link for help.
Roland Company Contact Us Contact Us
Patch not saving,write button is not working from the day i bought.i bought is 2nd hand.plez help
If you buy a second hand, it may have been damaged in mini switch (tact switch) under the WRITE button. You need to replace the tact switch. Easy and inexpensive, you can do yourself, only with a little knowledge of soldering
Tact Switch:patch-not-saving-write-button-not-yaafdoculwfzpmwkmuxstabs-1-1.jpeg
You may also try the FACTORY RESET.
Restoring the GT-10 to the settings made at the factory is referred to as a "Factory Reset."
Not only can you return all of the settings to the values in effect when the GT-10 was shipped from the factory, you can also specify the range of settings to be reset.
If you do this"Factory Reset", all the setting on user memory (that you create) will be erased, so backup your setting before doing this steps.
patch-not-saving-write-button-not-yaafdoculwfzpmwkmuxstabs-1-3.jpgpatch-not-saving-write-button-not-yaafdoculwfzpmwkmuxstabs-1-6.jpg
For more detail on "Factory Reset", read the GT10 user manual:
roland.com/support/article/?q=manuals&p=GT-10&id=1810803
I have a roland e96 trouble. Fist indikator in lcd internal battrey low, but not change the battey. now my roland e96 is blank.
You need to replace the battery. It will most likely be a coin sized battery in a slip in holder on the main board. If you need help, here is ROland Customer Service contact info-
Support Roland
After that, you can reset the E96 back to the factory settings by following the directions here-
Roland 96 Initializing the 70 86 96 Restoring the Factory Settings...
1helpful
Hi-hat is triggring sound while in the closed position. and splash can't be produced
Check the following on a VH-11 HiHat.... both cables connected correctly, top playing surface is clear of the inner ring on the lower sensor when in the fully up position, power the module OFF, keep sticks & foot well clear of the HiHat then power ON, finally check the calibration settings (I assume the 15 has that as my TD12 does) If still nogo check on the VDrums forum website....
Roland BOSS RC-20XL Loop Station will not record or play
If your Roland BOSS RC-20XL Loop Station will not record or play, there are a few troubleshooting steps you can try:
  1. Check the power source: Make sure that the Loop Station is properly powered and that the batteries or power supply are providing sufficient power. If using batteries, try replacing them with fresh ones.
  2. Check the connections: Ensure that the input and output connections are properly connected and that there are no loose cables. Try using different cables to see if that resolves the issue.
  3. Check the settings: Make sure that the Loop Station is set to the correct mode and that the input level is set appropriately. Refer to the user manual for guidance.
  4. Reset the device: Try resetting the Loop Station to its factory settings. Refer to the user manual for instructions on how to do this.
  5. Service: If none of the above steps work, the Loop Station may need to be serviced. Contact the manufacturer or a certified repair center for assistance.
Hopefully one of these steps will help you get your Roland BOSS RC-20XL Loop Station working again.
1helpful
My hihat controller has a problem sounds become
Make sure you aren't mixing up the cord for the hi hat pad and the hi hat controller.
Top Roland Music Experts
NOEL
NOEL
Are you a Roland Music Expert? Answer questions, earn points and help others
