SOURCE: Dell Inspirion 1000 power short circuit
Good Evening:
Hope that you are wellJ
If I can be of further assistance, please let me know
And, remember; always include the type of Operating System and the type of computer you own, when you submit your questions. It simply makes for much faster solutions.
Have a wonderful weekend.
SOURCE: no display
The LCD backlight is most likely faulty. If you look at the LCD screen to one side you could see a slight video image, provided the video card is working. To check if the video card is working connect the laptop's video output connector to an external monitor and then boot up your laptop. If you get an image on the monitor, then the problem is with the laptop's LCD display.
As I stated it could be the backlight or a faulty invertot that powers the backlight or it could be the cable/s that connects the LCD to the motherboard.
Try reseating these cables (requires dismantling the laptop).
If this doesn't work then you have a faulty LCD and needs to be replaced. Alternately if cost is too expensive, just use the laptop with an external monitor.
SOURCE: Dell Inspirion Laptop Screen Randomly Flickers, Then Blacks Out
If this laptop is only a few monthe old, then it should be still under warranty. I suggest you return it to the supplier for repair or replacement under warranty. If you try to repair it, most likely you wil void your warranty.
If you don't have this choice then read the following info.
You most likely have a faulty CCFL lamp or inverter, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
SOURCE: dell inspirion 1000 laptop computer will not allow
It seems there is a heat related issue on your laptop. I would suggest to run first the diagnostic test, to check for hardware problem.
Try removing any external devices first (Ex. USB devices) then run some diagnostic test:
1. Turn on computer
2. Tap F12 continuously on the Dell logo screen
3. Select Diagnostics
4. Follow on screen instructions
4. Wait for the test results (approximately 10-15min.)
If all test passed no problems have been found, it means there is no problem with hardware/computer. The problem is now pointing out to be software problem. Re-installing windows will fix the problem. Hope this helps
SOURCE: Dell Inspirion 1521 Laptop Microphone Wont Work
I have a Dell Inspirion 1521 same mic issue.....so it was corrected driver R167846
Title: Audio: SIGMATEL STAC 92XX C-Major HD Audio Driver
Version : A02
OEM name : SIGMATEL
OEM Version: 6.10.0.5609
Computers : Inspiron: 1420, 1520, 1521, 1720, 1721; Vostro Notebook: 1400, 1500, 1700; XPS: M1330, M1730
OSes : Windows Vista 32-bit Business,Windows Vista 32-bit Home Basic,Windows Vista 32-bit Home Premium,Windows Vista 32-bit Ultimate,Windows Vista 64-bit Business,Windows Vista 64-bit Home Basic,Windows Vista 64-bit Home Premium,Windows Vista 64-bit Ultimate
Languages : Brazilian Portuguese, Chinese-S, Chinese-T, English, French, German, Japanese, Korean, Spanish
Created : Wednesday, November 07, 2007
