Question about Dell Inspiron 6400 Notebook
How do i speed up my older pc laptop
Slowing down with age. Is there a reliable/safe way to make it faster? I've done disk cleanup and compression.
My system is running slow
Slow computer If you have a virus program installed, it is most likely is running a scan on your hard disk. It can slow down your computer especially if you have a large hard drive. After scanning is completed then the computer will be faster.
To make your computer (hard disk) lean and mean, uninstall any programs you do not use.
Also you need to maintain your hard disk by running Disk Cleanup this will remove old temp files and old compressed files etc.
This will reduce the number of files the virus scanner has to scan. Plus running Defrag. this makes your files contiguous so the system can access files off the hard drive quicker because it does not work as hard.. Disk Cleanup and Defrag should be carried out at least once a month.
If you have 512Mb of RAM installed then installing more RAM will speed up your computer. After installing your graphics card, you may need to disable the built-in graphics card in the BIOS for the new graphics card to work properly.
Apr 22, 2013 | Computers & Internet
What is the reason of very slow speed of laptop hp 6710b intel core 2 duo
Apr 20, 2013 | Computers & Internet
How can i get my pc to restart without taking much time?
Apr 17, 2013 | Dell Computers & Internet
Extremely slow running
Mar 29, 2013 | eMachines T5274 Desktop PC
How do i speed up my laptop
Mar 21, 2013 | Computers & Internet
How to make it run faster
If your computer has less than 1Gb RAM then install more RAM will help.
Feb 01, 2013 | Dell Latitude E6400 Laptop Computer PC...
I have a acer laptop that I let my son use and I've noticed that it is very slow and also it gets very hot. What do you think the problem is?
Dear Kristen,
1. Your laptop is running slow because there are too many applications running in the background. Go through the start menu and remove them if you don't need them.
2. Defragment your hard disks. Use a tool such as O & O Defrag Pro.
3. Your Acer heating up is a normal issue. Some older acer laptops heat up quite a lot. This is not an issue in laptops purchased after 1/1/2010.
If you are worried, get your laptop checked and serviced by a qualified technician or just simply hand it over to the nearest service center.
Oct 19, 2012 | Acer Computers & Internet
I have low memory and my laptop is slow
Toshiba laptops are not intrinsically slow computers and more often than not a slow computer is caused by a software rather than a hardware problem. Computers get bogged down by running too many processes at once, having the information in the hard drive stored in different parts of the disk (fragmented) and computer virus, worm or spy ware infestations. Of course, sometimes a computer simply doesn't have the hardware to run certain programs or will have a hardware issue that needs to be fixed.
Disk Cleanup
1.Click "Start/All Programs/Accessories/System Tools/Disk Cleanup" to open the Disk Cleanup program.
2.Select the hard drive that you want to clean up if you have more than one hard drive and then click "Ok" to get started.
3.Wait for the Disk Cleanup tool to calculate how much space it will be able to save by compressing your files. Compressing the files in your hard drive will open up space that in turn helps your computer access information faster.
4.Click the "More Options" tab on the "Disk Cleanup" window that appears and then click the "Clean Up" button within the "Windows Components" section. This will allow you to select what Windows Components you want to disable. Disabling Windows Components will make your computer software by diminishing the programs that are running.
5.Click the "Clean Up" button within the "Installed Programs" section. This will allow you to select what computer programs you no longer wish to have installed on your computer and uninstall them. Uninstall programs that have not been used in a long time such as old video games to speed up your Toshiba laptop.
6.Click the "Clean Up" button with the "System Restore" section. This will delete all but the most recent of your backup files so that you don't have useless backup files taking up space and slowing down your laptop computer.
7.Click the "Disk Cleanup" tab and then select all the files from the "Files to Delete" section that you want to delete. This will delete all those files from your computer making your computer faster by freeing up memory space. Click "Ok" to delete the files and exit Disk Cleanup.
Fan
1.Blow pressurized air from a pressurized air can into the Fan slits on the bottom and side of the Toshiba laptop to clear it of dust. A dusty, dirty fan will cause speed issues on your Toshiba laptop.
2.Power off the computer, remove the battery and all external devices and then unscrew all the screws that have a keyboard picture on it.
3.Remove the keyboard from your Toshiba laptop and on the inner, upper, left hand corner, on the side of the monitor, you'll see the fan.
4.Blow pressurized air into the fan to clear the dust and then replace the keyboard, screws, battery, external devices and power the computer back on.
Processes
1.Press the "Ctrl," "Alt" and "Delete" keys on your Toshiba laptop keyboard simultaneously and then select "Start Task Manager."
2.Click the "Processes" tab and take inventory of all the processes running on your computer.
3.Right-click on each process with your Username to the right of the process name and then select "End Process." Do not end processes that are vital to your computer running properly such as explore.exe or processes that don't have your username to the right of the process name.
4.Restart your computer if you end a vital process.
Sep 15, 2011 | Toshiba Satellite A45-S121 Notebook
My laptop running slow and net browsing very slow my configeration windows7 original ,320 gb HD,3GB memorry
There are several reason for the computer to be running slow for the start please try restarting the computer to safe mode with networking (Steps given below) and check if your browsing speed is better. If your internet browsing speed not better in safe mode with networking then you need to contact your ISP to complain about slow speed.
If it is working fine in safe mode, then some of the software (example: Antivirus / Internet Security / Firewall) is slowing down your computer. Please try removing it. Also try reducing the color scheme, use a non aero theme and see if your comptuer is working fine. If so your processor is not able to take the load of windows 7 visual effects aswell as other programs running in the background at the same time
Mar 02, 2011 | Computers & Internet
How can I make my laptop works faster?
You don't say what OS, assuming XP
I'd try the following:
Run windows disk cleanup and defrag
Run a cleanup program like ccleaner
Run a registry cleaner like regcure or eusing
If that doesn't help add more memory (you should have at least 1GB and preferably 2) or switch to Linux :-)
Jun 17, 2009 | Toshiba Satellite Pro L300 Notebook
Dell Inspiron 6400 Notebook Logo
65 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
