Question about Bunn VPR Coffee Maker
Why doesn't it produce hot water?
Replaced heating element
mr_coffee
    Problem Solver:
  • 7 Answers
The electric comes through your thermostat make sure it is turned on all the way clock wise, and then through the high limit Thermal Cut-Off .it could be either one. further testing is the only to know. also it will take 20 minutes to heat up from a cold start... make sure the tank is full of water before plugin in. it will burn your new heating element out in about 2 to 3 minutes..
Posted on Dec 18, 2015
1 Related Answer
Gort007
Just Gort
  • 1187 Answers
SOURCE: Water doesn't get hot enough.
Yes, they can be replaced; however, the element is not available to the public due to BUNN and UL requirements.
BUNN service: 1-800-352-2866
http://www.bunnomatic.com/RETAIL/service/faq.html#faq9
Posted on Oct 08, 2009
My Rheemglass Fury is not putting out much hot water
I believe that there are 2 separate electric heating coils in this unit (unless you are talking about the GAS unit). One of the coils either has a wire broken or the element needs to be replaced!
Dec 31, 2012 | Rheem Water Heaters
I have a bosch diswasher which is quite a few years old no sgs3042gb/03. the water isn't getting hot and it doesn't dry?any help will be grateful
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Aug 13, 2011 | Bosch Dishwashers
Water heater supplies about a pint of hot water than turns cold?? what is th eproblem
Hello Rsjohnson164,
I understand that you are having a problem with your hot-water tank not producing any amount of hot-water. I would suggest that you turn off the cold water supply to your hot water tank and drain the tank and see how much water comes out of it.
Flush the tank:
1. Turn off the cold water supply
2. Hook a water hose to the boiler valve (spicket on the bottom of the tank) and turn on the valve
3. Turn on the cold water inlet line and let it run for about 15 minutes or until you get good pressure coming out.
Check the Elements:
1. Turn off the power to the hot-water tank
2. Remove the service panels
3. Remove one wire from the element and use a multi-meter to check continuity
4. If no continuity replace one or both elements
If you do all of this and still have a problem repost to this thread and we will check your thermostats to make sure they are working properly.
Thank you for choosing FIxYa.com
Justin
Apr 21, 2011 | RELIANCE ELECTRIC WATER HEATER
Does not produce hot water.
Make sure the connections are all turned on and that their all in the right holes. It can also maybe be a problem with it's solenoid or thermostat.
Apr 18, 2011 | Dishwashers
We just recently replaced both heating elements in our water heater. Now the water is just barely getting warm and not hot. What's wrong??
Electric water heater if fully repairable by homeowner:
A] First of all, we know your upper element is working because you have some hot water:
http://waterheatertimer.org/How-it-works.html
That says tank is not overheating.
It says tank is getting 240Volts.
It we know water heater is 240Volts because you have 2 elements.
And it says reset button is not tripped.
B] That leaves 4 suspects:
Suspect 1) Bad Upper thermostat or Bad Lower thermostat: solution replace both thermostats for about 25$. Steps shown in link below.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
Suspect 2) Burned out Lower element: solution take out element, clean sediment out of tank, put in new element. Steps shown in link below
http://waterheatertimer.org/How-to-clean-sediment-out-of-electric-water-heater.html
Suspect 3) Loose wire or connection: solution open covers and remove insulation and look for signs of burning and high heat. Tighten all screws very tight. Replace burned part. Put insulation and covers back over thermostat so thermostat not exposed to cool air which will cause thermostat to misread tank temperature.
C] Before replacing anything, you can test water heater parts and determine exact cause of problem. Testing requires $5 multimeter from Lowes or Home Depot:
Install battery in multimeter.
When test calls for testing voltage, rotate multimeter dial to 240 or 250 or 277 Volts.
When test calls for testing continuity, rotate multimeter dial to ohms (upside down horseshoe symbol is ohms)
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
After doing 30 minutes of testing, you will be expert in water heaters.
D] You replaced elements for a reason
Did you test elements before replacing?
Was tank producing some hot water before you replaced elements?
If tank producing some hot water, then lower element was bad, and upper element was good.
And when you replaced lower element, did you also clean sediment out of tank?
If sediment builds up inside tank, it will reach lower element and burn out the element.
That could have been original problem, and it could be same problem again.
Restore full efficiency to tank by cleaning out sediment and replacing lower element.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
E} More reading to preserve tank and save money long term
http://waterheatertimer.org/Replace-anode-rod.html
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Dec 10, 2010 | Rheem Water Heaters
Rheem 50 Gal two 4500W heating element - not enough hot water
one element is off peak and one is boost could be thermostat or ripple controller in fuse box or one dead element
Apr 19, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
I have hot air but no hot water in my dishwasher
Check to make sure your supply lines aren't crossed and that your hot water supply is connected to the dishwasher
Aug 11, 2009 | GE Nautilus 24" Built-in Dishwasher
No hot water
under the handle of the faucet reached by removing the covering cap and single screw is a plastic geared device which limits the travel of the handle to the hot side carefully reorient so handle will turn a little farther and reinstall handle screw and cap
Jul 06, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Rinse not hot enough
145 degree is just your hot water temp and that your dishwasher hot water booster is not working assuming that this machine has worked in the past to produce final rinse water above 180 degrees. Remove the bottom panel and to the right you will see the booster tank, look for a nickel size component with a small red button on it. Try pushing on it to reset it. If that does not work, check for voltage at your heating element on your booster tank. (the thicker wires) If voltage is present then your heating elements need replacing.
Nov 13, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
We have a rheem electric hot water system which is suddenly not producing hot water. We have checked the electricity supply, the valve and both these were OK. We are at a loss to explain why this is...
Electric water heater are designed with two elements for heating the water. The upper element is what is called the quick recovery element which is control by a thermostat. The thermostat has a reset button that will open in an over temperature situation. If the reset is NOT tripped it is possible that the upper element or thermostat has failed. Until the upper element is satisfied ( up to set temperature) the lower element does not get any power through the circuit.
Jul 22, 2008 | Heating & Cooling
Bunn VPR Coffee Maker Logo
207 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
gbob59
Marvin
Marvin
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
