Question about Electrolux Washing Machines
Letters have faded on programme dial need a picture of where they should be
Electrolux aqualung 1000
Posted by Laura stewart on
Error code E20
Turn the dial to off.
Press and hold the start pause and nearest option button to it.
Whilst holding them, turn the dial one notch clockwise.
The machine will beep or flash, let go of the buttons.
Now turn the dial slowly through each position, stop and position 10 (9 clicks after letting go of the buttons) and note the error code displayed.
Continue turning the dial until you get to off.
Now turn to any programme, then, turn to off again.
Finally, turn to a programme and try the machine.
(It is very important that you turn to Off, a programme and then Off again).
Let me have the error code you retrieved if the appliance still doesn't work.
Oct 14, 2012 | Electrolux Washing Machines
Programme dial on Electrolux ewd 12141 has worn off and the manual does not have a picture. Can anyone help me??
check on e bay or contact manufacturer for replacement. failing that try searching online for an image of said dial and mark on setting you use with a permanent marker pen
Mar 08, 2012 | Washing Machines
The striker appears not to strike the Daisy wheel letters firm enough to produce a dark and clear letter. Many times the result is a letter not fully printed and it appears to be lighter along the left...
Please check the ink ribbon. There are two types of ribbons. The plastic one can be used once and if you try it the second time then there is no guarantee that all letters will appear fine and legible. (as may be happening in your case). The other is the cloth ribbon. This can be reused and it keeps fading as you keep repeating it. But in this case all letters are faded and nor selective.
Nov 22, 2010 | Lexmark Wheelwriter 1000 Typewriter
No instructions
Go to:
www.hotoint.co.uk.
Scroll down and click on www.hotpoint.co.uk.
Click on after sales and then click on down load instruction books, type your model number in and you can save it to your hard drive, or print it off.
Plz rate my solution.
Thanks.
Dec 16, 2008 | Hotpoint First Edition WMA12 Front Load...
Transfer calls
You need two things to do this. Call Forwarding and a class of service that lets you dial off premise. If you look under Call Forward in your user guide, you just set CF and dial 9 plus the number. It will either work or not. If it does not, then your system administrator/programmer will have to open up trunk to trunk connections for call forward external. There will be some class of service issues to allow only what is needed and prevent toll abuse.
Carl
Dec 09, 2008 | Inter-Tel ECX 1000 Telephone
Zanussi Electrolux FX 1265 W washing machine wont work
Chrisbounty
also not ure what you meant by fused did you have some kind of electrical arcing sparking wires melting?
Sep 20, 2008 | Washing Machines
Zanussi washing machine.
i am a recently retired engineer of 20 years, and i have found that generally the numbers and letters are the same throughout, so the number 2 on one machine is the same as the number 2 on another make, so this rule applies for letters also, just remember what you used on your old machine and you cant go far wrong hope this helps
Sep 19, 2007 | Washing Machines
Washing Machines Logo
Top Electrolux Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
