Question about Health & Beauty
When is my ELECHG1015 fully charged?
There is a red charge light and a yellow power light...How do I know when it is fully charged?
Posted by Elaine Beck on
5 Related Answers
oregoon
  • 175 Answers
SOURCE: only 1 battery charges
The lights are working, the batteries aren't. Red indicates power to the charger, and it should be on all the time. Green indicates a full charge, usually. If one or both of the batteries are totally dead, then the charger can't "see" them, and you will get a green light, but you will have dead batteries.
All power chairs use sealed, deep-cycle batteries. Deep cycle batteries, are designed for slow amperage dischare over a long time period, unlike a car battery that throws out a lot of amperage for turning the motor over. That's called "cold-cranking amps", and you can load-test a car battery to see if it will throw out a ton of amps for long enough to start a car. There is NO load tester made, or possible for a deep-cycle battery. A load test requires a 24-hour time period, and a complicated formula.
So, your course is to get some fresh, gel-sealed-batteries. You will need type U-1. Specify, gel-sealed-batteries when you go to the battery shop. A fresh set should get the chair up to about 12-16 mile range, which would be about 3-4 hours running constantly at high speed. Good luck.
Posted on Jul 09, 2009
Anonymous
  • 17 Answers
SOURCE: Will not turn on after charging
Sounds like it's time for new batteries.
Posted on Sep 22, 2009
Anonymous
  • 20 Answers
SOURCE: wheelchair battery charger will flash red
You didn't mention what brand & model of wheelchair/scooter you have. To properly check to see if the charger is working correctly is testing the total voltage of both batteries together while the charger is plugged in to the controller joystick. First check the total voltage of both the batteries together before you plug the charger in. The total voltage of both fully charged batteries together should be around 24.5 to 26.5 volts. Plug the charger into the charging port on the powerchair/scooter. Now with the charger on, the voltage should read at the very least 1+ volts more than the total voltage measured earlier. If less the charger is bad and will need to be replaced.
Hope this helps, if so please rate this solution which will help others who may have the same answer and thank you for using FixYa.
Flavadave75
Posted on Feb 03, 2010
HoverTech
Donna Angelo
  • 232 Answers
SOURCE: the battery wont stay charged
If the charger is automatically giving you a green light when you plug in the charger, the batteries are most likely damaged and will no longer take a charge. This can happen when the power chair is stored and the batteries are not charged for a while. The green light on the charger indicates the battery is full, but instead of being full of power, its full of crud. Try to replace the batteries and see if that will solve the problem.
Posted on Oct 04, 2010
HoverTech
Donna Angelo
  • 232 Answers
SOURCE: chair no longer charges, no flashing or blinking, lights,
The number of lights that are blinking indicate what the problem is. Visit this site to locate the type on controller on your power chair and you will be able to see that the blinking lights mean:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Try to reset your manual brake release as this is a common problem.
If you continue to have a problem, contact your manufacturer or dealer for service. If your insurance purchased they power chair for you, they may also cover the cost of repairs.
Posted on Oct 20, 2010
I have replaced joystick, batteries, motors and the chair still losing lights will go about 1/4 mile and loses all green lights with in 1/2 mile loses all the yellow lights, drove on 1 flashing light for...
Janice check your charger it could not be charging the batteries. Now always charge your batteries overnight while you sleep When you get up lights on the charger should be red and green if they are red and yellow then the charger hasn't fully charged the batteries and overnight should be more than enough time to charge fully. This could indicate a bad battery remember new doesn't always mean good. Like they say always charge before use and this goes for new batteries too you need to charge new batteries nightly for 10-15 days before they start operating at 100%. If when you plug in the charger before bed and the lights are red and green then there is a problem with the charger or the batteries or the charger circuit Hope this helps you
May 23, 2011 | Spirit Activecare /wildcat Foldable Power...
Ryobi charger model # 140295003 has a red and yellow light. When charging red light is on what does the yellow light mean? Also how long should the battery be left in the charger?
Completely wrong. Quoting from the user's manual:
"The charge indicator light (LED), located on the charg- ing stand, will light up red and glow when the char- ger is properly connected to power supply. This light indicates the charger is operating properly. It will remain on until battery pack is removed from charging stand or charger is disconnected from power supply.
After normal usage, 3 hours or less of charging time is required to fully recharge battery pack.
If both red and orange LED indicators glow, the battery pack is deeply or completely discharged, and 6 hours or longer of charging time is required to fully recharge battery pack.
Note: If charger does not charge battery pack or orange LED continues to glow after more than 30 minutes of charging, return battery pack and charging assembly to your nearest Ryobi Authorized Service Center for electrical check."
So to summarize: red = charging. orange (yellow) = fully discharged battery. orange after 30 minutes - bad battery or bad charger.
Apr 23, 2011 | Garden
How would i know when my Samsung camerais through charging
you can know if the camera is charging by the indicator light in the usb cable, green light means it was full charged..red light means that unit still charging.
Jan 28, 2011 | Samsung L200 Digital Camera
Do not know if chair is taking a charge lights just keep moving across armrest .how do u tell when fully charged?
hi let me see if i can help ,
When the lights go back and forth on your joystick that means the chair knows its pluged in .Now the chair itself has a built in charger that is mounted on the back of your chair .The back of the chair ,there is a opening a cutout in the frame .when you plug in your chair there will be a red light and a yellow ,yellow means the chair is charging, wait till it turns green,this means fully charged.When you plug in the chair youll see the lights through that hole.Look for the lights.
I recommend my customers to leave there chair charging over night look at the light it will be green when you turn the chair on the joystick should show fully charge.
Good luck hope i was of some help.
Jan 20, 2011 | Invacare Supply Group Invacare Pronto M51...
How do I know when the chair has charged? I see one red, two green, two yellow lights on.
If you have an off-board charger that plugs into the joystick there are two lights on the charger one red(power on) and the other yellow (turns green when fully charged). Plug it into the chair and if the light is green then you have fully charged the batteries. Now if you have the on-board charger the charger meter on the rear of the chair will resd zero when fully charged. Hope this helps ya
Aug 18, 2010 | Electric Jazzy 1115 Power Wheelchair
How do i know when my invacare pronto m5 is fully charged?
With an M51, a full charge will be indicated by all three joystick indicator lights lit- red yellow green. The green far right LED is the full charge light. Also the charger has indicator lights that go from red/yellow to full green at full charge. Hope this helps
Jul 11, 2010 | Invacare Pronto M51 Power Wheelchair
Lights on Rechargable Lantern.. Swissgear SG66301
I don't know how to solve your problem but, the three lights mean this:
Red LED light indicates the battery is being charged
Green LED light indicates that the battery is fully charged
Amber LED light incidates that the battery power level is low - the battery needs recharge.
Do not recharge you battery over 24 hours.
Nov 03, 2009 | Kitchen Appliances - Others
My glowbouy flashes green and red...what does this mean
According to the owners manual for these swimming pool lights, this is what each colored indicator means. Hope this helps.
Solid green
The battery pack is fully charged.
Slow flashing green
The battery pack is almost fully charged.
Slow flashing yellow
The battery pack is half charged.
Medium flashing yellow
The battery pack is less than half charged.
Fast flashing yellow
The battery pack has almost no charge.
Fast flashing red
A charging error has occurred and the light should be unplugged and then plugged back in. If the Fast Flashing Red persists after several attempts, the battery condition is questionable.
Also in the trouble shooting guide, it mentions this:
Problem: Red Indicator Light Is Flashing While Charging
Solution:
A red flashing indicator light when charging indicates a selftest
error condition. Unplug the product and plug it in again.
Try this several times; if the indicator light continues to flash
red, unplug the GlowBuoy and take it to an authorized service
depot.
Oct 22, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
My motorola H700 keeps staying red when charging
Wait, how long have you waited for it to charge? It's supposed to stay red until over 80% charge, then switch to yellow. When it is fully charged, it goes to green. When you mean it stays red when plugged in, have you waited the 2 hours?
Jul 10, 2007 | Motorola Mobility H700 Wireless Headset
Health & Beauty Logo
130 people viewed this question
Top Health & Beauty Experts
Marvin
Marvin
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Health and Beauty Expert? Answer questions, earn points and help others
