Solo se prende esa luz desconocsco el motivo por que no le falla nada.
2003 Jeep Liberty- Reading Engine / Diagnostic Codes ...
? 1:13
https://www.youtube.com/watch?v=pGrPBBzp7wE
Jan 6, 2013 - Uploaded by DeathScouter
2003 Jeep Liberty- Reading Engine / Diagnostic Codes ..... error code will flash 2 times, brief pause, flash 1 time, pause, flash 5times, pause, ...
2005 Jeep Liberty possible cause of P0442 error. - YouTube
? 5:26
https://www.youtube.com/watch?v=2ba-gH0gadg
Dec 21, 2014 - Uploaded by TheBGravit
While replacing a bad fuel pump I believe I found the cause of a P0442 Error code. I was able to repair the ...
Jeep Liberty Questions - Cylinder Misfire code - CarGurus
www.cargurus.com > Questions > Jeep > Liberty
CarGurusMay 27, 2009 - My jeep Liberty 2009 does the same the Dashboard showed a code of cylinder .... i have a jeep liberty 2006 with the # 5 cylinder misfire. i replaced the sparks... I have a 2005 Jeep Liberty 6 cylinder, engine light came on scaned the ... 2002 jeep liberty camshaft posistion sensor error code p0340 5 answers.
Check Engine Light/Misfire Due to Intake Valve Locks ...
repairpal.com > Problems > Jeep > Liberty
Recently got a second hand 2005 Jeep Liberty Sport. Everything worked fine ... #5intake valve seat dropped and held open the intake valve. 2008 Jeep Liberty.
OBD-II Trouble Code: P0305 Cylinder 5 Five Misfire Detected
www.obd-codes.com/p0305
SOURCE: tengo un codigo de falla P0301 se que es una falla
Verifica el retiro de los inyectores, podria tratarse de la obstruccion de alguno de ellos,
con residuos de agua y sedimentos en la gasolina. Hacer limpieza de los mismos, verificacion de o´rings, y un escaneo final para el borrado codigos.
No estaria demas, usar bujias mopar con
una grado termico mayor.
Suerte (recuerda valorar esta ayuda).
SOURCE: tengo un problema con my
Hola,
La primera cosa que hago es desconexi?n la bater?a y toca la terminal negativa sobre al positivo para reponer el ordenador. entonces lo comienza retrocede y ve si la luz regresa en
Yo entonces verificar?a con una herramienta de esc?ner pr?ximo y ver?a si ese cilindro todav?a falla y si es tirar?a la baranda de combustible e intercambio que cilindros abastecen de combustible inyector con uno del cilindro pr?ximo a ello y entonces lo corren otra vez con la herramienta de esc?ner y ven si el fallo de tiro cambia al otro cilindro.
Si usted todav?a tiene un cilindro 2 fallo de tiro, entonces yo sospechar?a que el luego.tambi?n de inyector de combustible verifica la buj?a y el rollo.
Permita que sepa, si ayuda adicional necesitada.
Espere que le ayudara.
¡Gracias por utilizar "Fixya" y tiene un d?a agradable!!
SOURCE: EL GOLPE SE PRODUCE SOLO CUANDO PASO DE LA
vey el nivel de aceite de caja de cambios ,falten TQF aceite minimo de una litro posibildad de una a medio litros
SOURCE: hola tengo una jeep liberty
Podria tratarse de una falla con el sensor de presion de aceite, no el de nivel, sino el de presion. Intente escanear el computador a ver si aparece algun codigo de falla.
Suerte.
SOURCE: EN MI SCANNER ME APARECEN
Ponle tape alrededor de la bobina para q apriete mas la bujia eso fue lo q me paso ami en mi liberty 06 y problema solucionado.
