Question about Delsey Helium Shadow - 25 Trolley Luggage : One Size
TSA opened our lock on our Delsey luggage, I now am unable to lock the suitcase. How can you reset the lock on the Delsey luggage after unlocked by TSA?
1 Related Answer
Micoman
Jorge Luis
  • 198 Answers
SOURCE: how to reset built in lock on my Delsey Helium suitcase
The default combination of new lock is always 000..If you forgot the correct combination, it is not possible to reset it.
Posted on Jan 07, 2016
Our suitcase is locked, and we forgot the combination. how can we reset the combination for our TSA approved luggage?
resetting the combination is only practical if the suitcase is open as the reset tab is located inside where it cannot be tampered with when locked.
if it is a set of dials lock a locksmith could help you.
regards,
Mar 25, 2018 | Luggage & Travel
How to reset built in lock on my Delsey Helium suitcase
Jan 07, 2016 | Delsey Helium Shadow - 25 Trolley Luggage...
How do I open a TSA combination on my Blue Star suitcase
Hey the key locked by mistake one side is locked and other side is not. It doesn't want to open what do I do help urgently on a trip.
Oct 03, 2014 | Locks & Locksmithing
How can I reset tsa lock on Delsey shadow luggage?
Ahh, you will have to try all 999 different combinations.
Aug 23, 2014 | Delsey Helium Shadow - 25 Trolley Luggage...
Eminent luggage lock
TSA lock on Eminent Osmosis Luggage, three digit TSA lock (HOW to change it to YOUR personal number)
Put the code numbers to '000'
Take the lock levers OFF the lock
Push the round opening button UPWARDS.
IMPORTANT :
KEEP holding the button UP until you have changed the numbers
Change the TSA code numbers to what YOU want
Release the round opening button
Now your case combo lock numbers have been changed.
To lock the case put the two lock levers into the holes, spin the numbers and your case will be locked.
To UNLOCK the TSA code spin the numbers to YOUR lock code, push the lock button UP and, hey presto, your case will open.
If you forget your NEW lock number you will NEED to go through ALL the numbers, starting at '000' to '999', to be able to open the lock/case.
REMEMBER to PUSH the ROUND OPENING button UPWARDS on EVERY number change.
Only THEN, when it finds YOUR correct three digit number, will it eventually open the suitcase/luggage/baggage.
Good luck
Aug 31, 2013 | Luggage & Travel
I have a somesonite 30in hardshell , uprite about 20 yrs old. has 2 key locks, as well as combanation center lock. question how can i set these locks so that, they are TSA excessable locks??? PLS. Help ...
You can have the locks changed but, that will cost almost as much as new luggage. They will have to be kept unlocked and a TSA strap will be needed around the suitcase.
Oct 07, 2010 | Samsonite Silhouette 11 Hardside Spinner
Problems to open a Samsonite TSA 007 lock on suitcase
Hi I have a problem to aopen my luggage I think my niece has change my security code accidentally , but now I cannot open my luggage can you please chelp me out?
Nov 08, 2009 | Samsonite Tripod
Delsey Helium Shadow - 25 Trolley Luggage : One Size Logo
2,250 people viewed this question
Top Delsey Luggage & Travel Experts
Tom Chichester
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Delsey Luggage and Travel Expert? Answer questions, earn points and help others
