Question about Hamilton Beach 40996 Programmable 1.7 Liter Kettle
Kettle not heating up water but electricity is reaching the kettle
Duff Howell
    Master:
  • 403 Answers
Hi Anonymous.
You can find the manual here
http://kitchen.manualsonline.com/manuals/mfg/hamilton_beach/40996.html and it echoes most of what I'd have to say. You've checked power getting to the kettle (I'm assuming this means that the base unit has displays coming on, etc). After that.....
  1. Heating element could be out, though that seems unlikely - most commercial elements are pretty robust. As with a lot of consumer goods these days, you'd be dodgy about whether a replacement part could be ordered.
  2. There is mention in the instructions about safeguards for if the kettle boils dry. If it happened recently , the auto-shutoff might still be engaged. It might need unplugging, a longer time to cool, or perhaps being filled with chilled water and left to sit and cool things with the water.
  3. There is also mention that if the system needs to be de-scaled, the restricted water flow can lead to the boil-dry sensor being tripped. You might want to try de-scaling the system.
Hoping this helps!
D
Posted on Dec 08, 2015
Claude Kayser
    Top Expert:
  • Hamilton Beach Master
  • 9,098 Answers
How to fix an electric kettle part 1 - YouTube
? 4:51
https://www.youtube.com/watch?v=P4dcq5p0FyU
Apr 15, 2013 - Uploaded by Anthony Findlay
how to troubleshoot and fix an electric kettle. ... I am using akettle had small problem the switch was not working so I have tried to fix it but I am ...
HOW TO REPAIR ELECTRIC KETTLE - Fix Your Electronics ...
electronicsolutn.blogspot.com/2012/10/how-to-repair-electric-kettles.html
Oct 25, 2012 - Electric Kettle is a kitchen appliance that contains a heating properties used for boiling water, cook food etc. It is made up of a metal or plastic ...
electric kettle light but not heating Questions & Answers - Fixya
My Breville water kettle stopped heating water. This is my second teakettle to do this. We have had this second kettle for about 2 years. We always were careful to make sure the kettle is off before
Unless you can take it apart and repair it yourself, it probably isn't worth the cost to have it repaired. There are several websites that sell parts, but you really have to be familiar with electrical circuits to diagnose it. Possibilities are:
1. It could be the thermostatic switch that turns it off as it reaches temperature. These are little devices with two wires connected and are in the base of the unit. these normally reset themselves but can stop working, especially if they have gotten wet.
2. It could be the cord to the unit with a wire broken at the base or the plug end.
3. It could be a thermal fuse; these are about 1/4 inch in diameter and may be hidden in an insulating sleeve near the element; they are sensitive to both heat and current.
3. It could be the element is burned out.
Link to a parts supplier is enclosed
Breville Kettle Parts
Feb 04, 2015 | Breville Kitchen Appliances - Others
No light, no water heating
The heating element may have failed.
Sep 11, 2012 | Braun WK200 Electronic Water Kettle...
My electric kettle is starting to break.
It sound like the temperature sensor that switches the kettle off when it has reached the correct temperature is faulty. It would probably be cheeper to replace than repair
Feb 18, 2012 | Chef's Choice 677 Cordless Electric Kettle
My Breville kettle does not beep anymore when the desired temperature has been reached.
Might not work, so don't cuss me if it doesn't, but have you tried demineralizing it? Pour it full of white vinegar, let it heat to about 160-180 and then turn it off and let it soak for a couple of hours. The vinegar will dissolve any mineral deposits on or in the heating system. Mineral deposits are the bain of electric water heating systems of all types. Drip coffee makers, 95% of the time, a premature ***** is due to mineral deposits. It also destroys house hot water heaters.
Aug 27, 2011 | Breville BKE820XL Electric Kettle
Why does the water boiled in this kettle smell and taste chemically? Any boiled in a plastic kettle in my home is fine.
hello,
the chemical taste of smell from your kettle means that the element in the kettle which provide heat to boiled the water has gone bad due to over heating
this occur when there is shortage of water level in the kettle when the power supply is on
to fix up this problem of smell and chemical taste in your boiled water you will have to make a change of the element (heater)because it has gone bad you can get a replacement of it in the store .
thank you and thanks for using fixya.
Jun 01, 2010 | Morphy Richards 43072 Cordless Electric...
MG32 Cordless Electric Kettle: Power light shows on my kettle but water does not...
sounds like there's water in the element. Empty it out and let it dry out completely for a few days, and then try it again.
If the element is a concealed element (ie- you can't see the coils when you open the lid up) then there's probably a water leak into the sealed compartment.
Contact the manufacturer for a recommended repairer.
May 17, 2010 | Alessi MG32 Cordless Electric Kettle
How do I clean
Fill kettle until 3/4 full with 1 part vinegar and 2 parts water. Boil and allow to stand overnight.
Empty solution from kettle. Fill the kettle with clean water, bring to boil and discard water. Repeat and the kettle will be ready for use.
Or you can use a proprietary kettle descaler, which is available at most hardware stores.
May 16, 2009 | Breville SK550XL Electric Kettle
Can kettle be cleaned and continue to be used.
I use a solution of vinegar and water (1:1) and boil it in the kettle, to remove mineral deposits from the metal heating surface (We do the same with the percolating coffee maker and run it through several times)... It seems to take any residual tastes out of the unit and possibly also cleans the plastic parts that it touches (I believe it does).
By the way... WHO thought it was a good idea to heat apple cider in an electric kettle. Sorry but WOW
Feb 24, 2009 | General (102105011) Electric Kettle
Hamilton Beach 40996 Programmable 1.7 Liter Kettle Logo
5,137 people viewed this question
Top Hamilton Beach Kitchen Appliances - Others Experts
Marvin
Marvin
Vincent G
Vincent G
Harjeet s. bola
Harjeet s. bola
Are you a Hamilton Beach Kitchen Appliances - Other Expert? Answer questions, earn points and help others
