Question about Seiko Melodies in Motion Clock
The clock stopped working. I changed batteries, but still doesn't work. the movement and melodies work, just not the clock. What should I do?
Posted by Frances Buckner on
UsedClockPartsdotCom
  • Seiko Master
  • 277 Answers
You may need to try to repair or replace the quartz movement, this link will help you out.
http://usedclockparts.com/14-clocks/clock-videos/126-quartz-battery-operated-clock-movement-repair
Posted on Dec 30, 2016
How do I change melodies?
The melodies should change each hour on it's own. You can change the melodies manually by pressing the demo button repeatedly. If the songs don't change each hour, you might try new batteries. I'd recommend Japanese batteries like Fuji, or Toshiba. I use Varta which is a German brand battery that's equivalent to either Duracell, or Energizer, and have no problems. If you've had the clock for a number of years, or have had it hanging in direct sunlight, or near a heat source it could be in need of professional assistance, and or repair. (if possible)
Mar 01, 2015 | Seiko Melodies in Motion Clock
Why will my clockl no longer play song or move
When was the last time it was serviced? The movement probably needs a good cleaning and/or oiling
UsedClockParts.com
Sep 02, 2014 | Seiko Melodies in Motion Clock
Chouchin ch 899
Jul 11, 2014 | Home
Motions will not work but time and music does
That just happened to me, check and make sure you have the batteries in correctly for the movement part. They are both supposed to be in the same direction on my clock for the movement and I had the AA batteries in opposite of each other!
Nov 12, 2013 | Seiko Melodies in Motion Clock
I need to know how to set a Seiko Melody in Motion clock that I just purchased at a resale shop. It is working but the time is wrong. It is oblong with 4 clowns at the bottom. Thank you.
i had that clock hre. and all the insides are special from seiko, i would send it to them. the movement is encased in plastic and some lever rods attached to them . may be worth sending
Jun 17, 2011 | Seiko Melodies in Motion Clock
Seiko Melodies in Motion Clock Logo
1,327 people viewed this question
Top Seiko Home Experts
Janelle Schoonover
Janelle Schoonover
k24674
Bruce Robin
Are you a Seiko Home Expert? Answer questions, earn points and help others
