Toys Logo
Debra Oneil Posted on Dec 07, 2015
How can i tighten car electric connection on new bright holiday express train 387?
All works, but the tanker and candy dancer electric connections wiggle loose every time arounnd. Running without those 2 ,all is fine, so its not the sockets on the other cars... Just the plug on those 2 cars. Is there a replacement? Can you use something like a small rubberband as a gasket? Tape dont work..tried that. Going to try trimming strip from 3m hooks or use thin strip of 2 side tape.. But I don't have faith in it. Thinking about hot glue or Elmer's glue applied carefully. Concerned about super gluing, need to remove to store. Any better options?
  • Debra Oneil
    Debra Oneil Dec 08, 2015
    Solved! I took the log car off, and took candy dancer.. Then , in my lap, hooked the electric as tight as I could, getting ready to 2 side tape.. When I heard a slight click! It snapped in tight! Did the same with tanker... It clicked too! Then i had to juggle them to track! 2 person set up would help! No tape needed, just a new set up method! I was railing then hooking up..
5 Related Answers
Bob Moody
  • 14 Answers
  • Posted on Dec 16, 2009
SOURCE: I believe my New Bright Holiday Express train set
Yes they do. I have the #380-2 Water Tank car (and the other 4 that are available) They run and operate just as the other cars do.
Testimonial: "Thanks for the quick reply. This will really help!"
Bob Moody
  • 14 Answers
SOURCE: New Bright Holiday Express Animated Train - figures do not move
Make sure you the wheels on the cars are actually rolling and not sliding (being drug down the track) Most of the animation is down mechanically as the set moves.
Anonymous
  • 5 Answers
  • Posted on Dec 24, 2009
SOURCE: an electricalroblem with Holiday Express train
This train set is very particular and getting it to work each Christmas is a family tradition in frustration. First you must make sure that all the pieces of track are connected properly and that the track is perfectly symmetrical and flat. We double-check the battery positions every year and find one in wrong. There are + and - signs, but they're hard to see; use a flashlight. There is a black toggle switch below and behind the red stack that toggles forward (to make the train go forward) and backwards (reverse); straight out perpendicular to the train is the "stop" position. Also, you have to start at a stop/switch station. One other note: behind the red stack, there is a smaller black stack. If you turn this, you can make smoke come out of the stack. I think I remember someone suggesting a drop of cooking oil. Hope this helps!!! Hope you get it set up for Christmas!!!
Anonymous
  • 6 Answers
  • Posted on Jan 16, 2010
SOURCE: Scientific Toys train won't run
WELL WHERE EVER YOU BOUT IT FROM YOU SHOULD TRY TAKING IT BACK THERE AND GETTING THEM TO LOOK AT IT,TAKE IT TO THE SHOP,OR BUY A NEW ONE. :)
geo5734036
George Hels
  • 528 Answers
  • Posted on Nov 20, 2010
SOURCE: Dear FixYa ... I have a
Is the train new and if not, has it ever gone forward in the time you've had it? Also have you tried putting the train on the tracks facing the other way - what happens?
Hello, have a New Bright Holiday Express Train No. 387, the train will not speed up and the track clip is heating up.
If the track clip is heating up, you have high resistance at the point the clips fits or in the rail joints themselves. Undo all the track joints and spray them with electrical switch cleaner. Clean the upper rail surface with a green pot scourer as that is where the train gets its power.
https://www.google.com/search?q=electrical+switch+and+contact+cleaner
Dec 09, 2022 • The Toys
What are the soldering points for a New Bright Holiday Express mod:380b tender car
why don't u try online websites..
some websites deal in it real time.. along with solutions to problems how to repair fix service nd all
let me know if u need help I know plenty
New bright greatland holiday express train
Check the connection from the transformer to the track, and that all the track is well connected. Make sure nothing is touching both tracks, shorting them out.
2answers
Are transformers for the 387 and 384 interchangable?
Check the output of the transformer going INTO the controler. Mine is 19VAC. IF the controler is working you should measure 25VDC between the inner and outer track with the controller switched on. If you have the AC but not the DC voltage push the red reset button. Once you have the 25VDC put your train in place (engine and coal car) and it should run.
2answers
We are having difficulty turning on our New Bright Holiday Express Animated Train set. Husband and I have been trying to figure this out for our eager 2 little boys. The remote seems to turn (red light)...
Here are a couple of resources from New Bright:
http://www.newbright.com/public/electric-train-faq
http://www.newbright.com/images/Manuals/384%20ws%20manual.pdf
There is no On/Off switch on the train. Power goes from wall plug to transformer, then from transformer to track clip, which must be attached to the track. A control line goes from the track clip to the controller. Mine has a green light just above the red On/Off button that will come on even if the engine and tender are not on the track. The tender does all the work, and must be connected to the engine and on the track. There are four sliding contacts between the tender wheels that provide contact with the track.
Each yr my New Bright Holiday Express train gets slower and slower the longer it runs. Finally it just stops. Every thing else seems to work: lights, etc.Train shop specialist say its the engine, not the...
check the electrical current to the trans former , then check the out put from transformer, may not be getting adequate electricity flow to operate , and if you continue to operate under required current , it may damage engine and or transformer , gd luck
2answers
I have a Newbright Musical Holiday Station Electric Animated set No. 385. Everyt car on the train lights up but we can't get the train to move or take any of the commands from the control panel. What could...
Check to make sure you have the large plug from the tender car to the loco plugged in correctly and secure. The tender car supplies power to the loco and if that cable is not connected the train will not run.
Top Electric Toys Experts
ADMIN Andrew
ADMIN Andrew
NOEL
NOEL
Are you an Electric Toy Expert? Answer questions, earn points and help others
